Old 11-09-2008, 08:53 PM   #1
murdoc
murdoc's Avatar
3 speed overdrive!!, now about getting it in.......
after years and years i finally scored one of these overdrive units. im excited to get it in, but not quite sure how to do it for our year trucks.
i have the common non syncro'd 3 speed on the column in now, so im wondering if i can use the same column and shifter arms that i have already. anyone made the conversion from the 4 bolt side cover non syncro'd, to the fully syncro'd 7 bolt side cover saginaw? anyone have any tips for me?
murdoc is offline   Reply With Quote
Old 11-09-2008, 11:49 PM   #2
murdoc
murdoc's Avatar
Re: 3 speed overdrive!!, now about getting it in.......
bump
Old 11-10-2008, 12:07 AM   #3
HOTFUN
HOTFUN's Avatar
Great score. I put one in my 56 BelAir and I had to swap the transmission levers and modify(cut/reweld for new angle) the front lever to get the right angle to my floor pan on the 56. I used my original (56) shift linkage but my car also used a bell crank linkage for the 2nd/3rd lever. You might get by using the original linkage and not modify your levers too. Just bolt it right back into the truck where your 3 speed came out and start checking the linkages and clearances. I had my 1st/rev linkage off at least a dozen times bending it in the vise. I think it works great now. You might have to work on your speedometer gear if your rear end is not a 4:10. I had to use a AC reduction box on the transmission to get my speedo to read near right.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 11-10-2008, 12:27 AM   #4
joe231
joe231's Avatar
i have no info, but wanted to say "cool!"
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-10-2008, 01:18 AM   #5
murdoc
murdoc's Avatar
thanks guys, i was worried i would probably have that problem, a lot of adjusting to get it right, but i guess its pretty naive of me to expect anything different, i will take pics of my progress...
Old 11-10-2008, 02:52 AM   #6
HOTFUN
HOTFUN's Avatar
Good luck. It is one awesome tranny when you get it all right.
'72 GMC K2500 4x4
Old 11-10-2008, 08:30 AM   #7
1restorick
1restorick's Avatar
Sir, I have this transmission in my 1963 truck and it looks identical to yours. My column shift linkage is stock. This transmission works real nice, however my first gear is still non-sychromesh. The overdrive feature is awesome and with a 4:11 rear gear, I only spin 2000 rpm at sixty miles per hour. Best of luck in the install. It should be very straight forward. You will need a heavy duty relay and a gas pedal switch for the kickdown feature. Building a wiring harness for this installation is very straight forward.
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 03-13-2009, 12:38 PM   #8
Texasdeere
Texasdeere's Avatar
Have you got it hooked up yet? How do you like it?
Texasdeere is offline   Reply With Quote
Old 06-28-2009, 09:06 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
Rick
I am interested in finding one of these and installing in my 66 C10. Can you provide info as where to look for them and what to look for in terms of their condition?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 03-13-2009, 12:47 PM   #10
Rogue
Airport Bum
I understand you can put that OD unit on a Saginaw 4sp too.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 03-13-2009, 11:17 PM   #11
Texasdeere
Texasdeere's Avatar
I found a Saginaw Overdrive tranny just like this one with the 7 bolt side cover. I am hoping it is a syncro first gear. I think it would be a cool bolt on for my 59 Apache.
Old 03-14-2009, 02:22 AM   #12
murdoc
murdoc's Avatar
yep, they are synchronized first gears, the seven bolts are at least.
No, I havent gotten this one in yet, for good reason though...right after buying this one, I found another 3 speed overdrive for sale for $100.00 Its the four bolt non sync'd version, but still, for a hundred bucks i can't complain.
I went through this entire tranny on the inside and then cleaned and painted it. I figured since i have never driven an overdrive before, I learn on this less expensive version and not risk the seven bolt.
Ill post pics of it in my truck later this weekend, I might start a thread on rebuilding a three speed steering column too........Its what has delayed my project for this long.....
Old 03-15-2009, 02:43 PM   #13
aboz
aboz's Avatar
Will you be selling one of those trannys when you've picked the one you want in your truck? I've been looking for one since I bought my '63 a year and a half ago. Will the same drive shaft work or will you have to get a shorter one? please let us know of any mods you have to make and post progress pics!
ABOZ
aboz is offline   Reply With Quote
Old 03-16-2009, 12:36 PM   #14
murdoc
murdoc's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 03-16-2009, 04:12 PM   #15
slorio
slorio's Avatar
Count me in too! I have a 7 bolt in a UPS truck that is supposed to get delivered today. Mine is going in a 1966 GMC with a 305E V6. Are any of you folks running a floor shifter on your OD? I am a little concerned about clearance issues with the solenoid? I have stock wiring diagrams downloaded if anyone needs it.
Regards,
Steve
New Orleans.
slorio is offline   Reply With Quote
Old 03-16-2009, 08:08 PM   #16
Joemomma1
Joemomma1's Avatar
What kind of vehicle has these? Wouldnt a 700R4 be simpler?
Joemomma1 is offline   Reply With Quote
Old 06-15-2011, 02:35 PM   #17
SulphuriousSam
SulphuriousSam's Avatar
If you wanted an automatic. I believe he's talking manual tranny here. I may be totally mistaken but that's how I read it. And from my point of view if it don't have 3 peddles you might as well go get a lincoln continental haha.
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 03-16-2009, 09:02 PM   #18
texanidiot25
Eat My Rust
texanidiot25's Avatar
Not entirely, a shortened driveshaft is needed, parts for the TV cable (absolute must), wiring to shut down the lock-up converter, moving the trans x-member back.
And it's not a stick.
texanidiot25 is offline   Reply With Quote
Old 03-17-2009, 11:53 AM   #19
aboz
aboz's Avatar
ABOZ
Old 03-17-2009, 06:47 PM   #20
murdoc
murdoc's Avatar
well alright i didn't get to posting these pics as soon as i had planned. anyways, here they are: I mated my o/d to a 250 inline to hopefully get the best fuel economy while driving my truck this summer, the 3:73 posi is expected to help out as well.
It was originally a four speed truck with a REALLY tired, oil caked 283. did the tall hump to small tranny hump conversion, rebuilt one good 3 speed column out of three columns i had, and working on the overdrive cable and wiring today............
I'll be talking to that guy with the overdrive tomorrow 3/18. I'll keep ya'll posted
Old 03-17-2009, 07:18 PM   #21
aboz
aboz's Avatar
Thanks Murdoc. I'll stay posted. I've got a 250 that originally ran in a 1970 Nova. Please update me on the overdrive cable and the wiring as I know nothing about how to upgrade to this type of transmission. Let me know how your gas mileage works out as I have 3.73 gears as well.
ABOZ
Old 03-18-2009, 07:22 AM   #22
BluTrukker
BOHICA
BluTrukker's Avatar
Did someone say you can bypass the solenoids and fabricate something to engage it manually? That would be great as I have been having no luck finding new electrical components for mine.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 04-27-2009, 12:24 AM   #23
murdoc
murdoc's Avatar
Hey to all who might be interested, I found a great chapter on these overdrive transmissions in an old hot rod book from 1968. It has some great info and wonderful pics of how to disassemble and reassemble the muncie version of these overdrives (the nonsyncronized ones). I know how hard info on these can be to get. I think it has better schematics than the current pdf files that are readily available online.
If any of you are interested in getting it, I have it scanned, send me a pm and ill email it your way.
The best of luck my friends, we who dabble with these nostalgic, innovative pieces of automotive history; we know we need it!
Old 06-15-2009, 09:39 AM   #24
slorio
slorio's Avatar
Just thought I would post an update. The overdrive transmission is now in my 1966 GMC behind my 305 V6. The results are sweet. Overdrive kicks in automatically after 30MPH. Gives a .70 to 1 ratio that is ideal for cruising at highway speeds. I think the old V6 is really going to love it.
If you follow this thread, UPS was kind enough to smash the governor in shipment and wouldn't honor the shipping insurance. Shipping insurance is a rip off. I ended up finding a new governor on E Bay, but it was 1.25" diameter threads for the early transmissions vs. mine with 7/8" threads for the later synchro transmission. Fortunately, I have a machine shop in the family and a nephew that was kind enough to cut and rethread the governor I bought.
These transmissions are a great way to get a cruising gear in our old trucks.
Regards,
Steve
New Orleans
Old 06-28-2009, 10:44 PM   #25
70 Suburban
Rods
i to would like to know about what to look for. I have a 3 speed on the tree colomn on stanby just for this
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
