03-09-2009, 07:13 PM | #1 |
Help! Chev S 10 rearends don't measure up??
I have found two chevy s 10 rearends. They are from an 88 & 89.
I am told they measure 48" & 52" backing plate to backing plate. From what I have read and searched it is my understanding that I need between 58-62". I thought the S-10 rearend was good? I haven't purchased one yet so I still have options. Can someone shed some insight. I have the link showing the various vehicles but am I looking at the wrong measurement using back plate to back plate? |
03-09-2009, 07:18 PM | #2 |
Insert Title Here
Re: Help! Chev S 10 rearends don't measure up??
not sure about first gen S10's...but the second gens are
2WD rear assemblies are 54.5" wide 4WD rear assemblies are 59" wide ZR2 rear assemblies are 63" Wide
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-09-2009, 07:27 PM | #3 |
For the s10 swap it is recommended to either run a 4wd s10 rear end cause it is wider than a 2wd. Or you can run a camaro rear end like I am. If you run a 2wd you'll have to tub the bed and do some other cutting that I'm not sure of. Best to make sure you are running a 4wd or camaro.
Later, Josh |
03-09-2009, 07:45 PM | #4 | |
I'm thinking that maybe it is drum to drum? Then the one I have at 52" would likely fit. Yes? No? Both of these are 4x4. The truck is at my buddies shop otherwise I could just measure what's on it. Last edited by 4DSEVEN; 03-09-2009 at 08:58 PM. |
03-09-2009, 09:00 PM | #5 |
Yellow truck club
I think it's mounting surface to mounting surface.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
03-12-2009, 12:08 AM | #6 | |
Commander Taco Bello
This basically means that a 52" - 56" rear would work for me. This assumes i tub it to the frame rail and that wheels have a 5.5" backspace. here are the tires that i'm estimating will work: * used this site for the tire dimensions: http://www.wheelsmaster.com/rt_specs.jsp Also, based on my calcs, with a stock setup (no tubs) you need the 59" rear, but can only run a 6" wide tire. This assumes 1" of space on both sides of your tire, on both sides of the truck. uhg, my head hurts.
03-10-2009, 03:37 AM | #7 |
Registered Chevy Owner
what ever you do get the wider one. i just got my rear end (89 s10 4x4) and it is still not enough, I'm going to have to get wheel adapters also, but i also want to run a wider rear tire.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
03-10-2009, 06:43 AM | #8 |
03-10-2009, 07:12 AM | #9 |
and a few others
I've got both 2wd & 4wd first gen S-10 rears if you need any measurements.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
03-10-2009, 12:58 PM | #10 |
Ok the box width is 50" and my axle is 52. Does this mean I will have to tub the box? Or can I use spacers?
Also am I going to have a difficult time finding rims to fit? Should I try to locate a wider axle? Any help is appreciated. |
03-10-2009, 01:31 PM | #11 | |
i am going to go with the ford pattern also ont he front rotors so everything will match... If the rear end is to short you are going to have to back half the truck and move the frame rails in... Plus the wheel tubs...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
03-11-2009, 12:04 AM | #12 |
I haven't had the opportunity to fit a box to mine yet... just wanted to confirm the actual measurement sizes on the 4x4 rear. I just went out to the shop and measured the backingplate distance.
Cheers, Ted. |
03-13-2009, 03:50 AM | #13 |
4dseven,
i haven't measured my axle. but i will and i'll get back with you on it. don't go cuttin' up your bed and frame yet. i'm not going to tub mine and i'm going to try to run 10" wheels. i'll take pic's and let you know what i end up doing.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 Last edited by nickp51chevy; 03-13-2009 at 03:58 AM. |
03-13-2009, 12:28 PM | #14 |
I have gone ahead with the S 10 rearend and expect to have it in my posession this weekend.
From all the information I have read and through everyone's on going discussions I believe I am on the right track. No plan to tub unless I have to, but will cross that bridge once I get there. Thanks to everyone for their input. |
03-13-2009, 02:18 PM | #15 |
my rear end looks to be 53" b/p to b/p. as you can see in the pic i just need to get a wheel spacer and I won't have to tub or cut anything.
