Old 04-05-2009, 12:26 AM   #1
87 dually burb
my short bus
87 dually burb's Avatar
90 burb (( daily dragger))
so I sold the 87 dually and bought a 90 2wd
started off like a grampa cruiser
removed a few things and dropped it a little
before the drop with acessories
after the drop removed most acessories
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 04-05-2009, 12:31 AM   #2
87 dually burb
my short bus
Re: 90 burb (( daily dragger))
swapped on
chrome front bumper with no rubber strips
clear tails with led bulbs
removed body molding, rear bumper,bug shield,vent shades
truck rallies
things to do :
weld in rollpan
clean body of trim adhesive
remove all drip rail molding
cut down front cups
add bags in rear
Old 04-05-2009, 12:43 PM   #3
merlot566jka
merlot566jka's Avatar
what did you use to drop it? What size of tires are on it right now?
looking forward to seeing your roll-pan pics, I was sent a truck roll pan and had to make it work....its interesting!
merlot566jka is offline   Reply With Quote
Old 04-05-2009, 05:31 PM   #4
87 dually burb
my short bus
front is a SD brackets w/airlift 2600 bags
3" bell tech spindles
trimmed rain gutters on lca's has truck rallies on it now
rear is just a 6" flip with no overload spring has about 1.5" to frame
roll pan I got from sir micheal's with no tag box
tires in above pics are 31x10.50x15
still had inner fender in sat on them
will up date with new pic's with 235/75-15 and no inner fenders
on monday
Old 04-05-2009, 06:21 PM   #5
87 dually burb
my short bus
from today after a bath
compared to my wifes stock explorer
fun I think
Old 04-05-2009, 09:02 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks good man, I love the long and low look..
tvblazer78 is offline   Reply With Quote
Old 04-05-2009, 09:20 PM   #7
vern350
like a rock
vern350's Avatar
Looks real good sitting low. Rally's look good aswell!
vern350 is offline   Reply With Quote
Old 04-08-2009, 10:40 AM   #8
justpball
justpball's Avatar
nice bro! killer ride!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-08-2009, 10:51 AM   #9
Cherub
Cherub's Avatar
nice ride. I definatly want a burban one of these days.
Cherub is offline   Reply With Quote
Old 04-08-2009, 01:57 PM   #10
factory2wdblazer's
factory2wdblazer's's Avatar
clean burbbun look's good on rally's.
factory2wdblazer's is offline   Reply With Quote
Old 04-08-2009, 02:42 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Long, low and slow.... looks good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-08-2009, 09:22 PM   #12
87 dually burb
my short bus
update friday I'm ordering some sd axle mounts the under and behind ones but I'm going to run them facing forward and use the frame as my top mount welded on axle about where the shock mount is now then going to weld in a 4" pipe as a notch so I can add my bump stops and not lose any drop
drop is about done for now next step is some body work and shaving
Old 04-09-2009, 09:14 AM   #13
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sound cool, get us some pics..
Old 04-14-2009, 03:40 PM   #14
87 dually burb
my short bus
bought another set of rally's with new tires
adding air shock for now may be a week or 2 for progress
(honey do list is calling)have to paint a few rooms and fix up the yard
Old 04-14-2009, 10:55 PM   #15
OrangeAnimal
OrangeAnimal's Avatar
Cool Burban!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-15-2009, 01:19 PM   #16
justpball
justpball's Avatar
cool bro keep us posted!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-20-2009, 09:54 PM   #17
87 dually burb
my short bus
So I'm going to give in and buy a 10" notch for rear
going to make it all work with only raising the floor about 4"s
should give me about 5-6" of drop
suspension wise I going to keep the 2 longest springs and add a block if needed
will be able to keep 3rd row seat on bridge cover and not lose any foot room
seat will be raised about 2"s at most
notch and bridge will be the only parts above the stock floor just for clearance issues
Old 04-22-2009, 08:51 PM   #18
87 dually burb
my short bus
8" i.d. pipe 2.5" tall
1/4 " bottom plate
starting on my dropped lca cups on sat
Old 04-23-2009, 01:50 AM   #19
flamingbig10
6.0 powered square
flamingbig10's Avatar
cool burb
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-23-2009, 06:37 PM   #20
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet man, post some more pics when you start
Old 04-23-2009, 10:48 PM   #21
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I might have to ride over and hang out some this weekend...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-24-2009, 11:44 AM   #22
87 dually burb
my short bus
hoping to weld them up saturday after helping friends move should have them back on sunday and finish cutting the inner fender for clearance
pic's sunday after installed/clearanced
Old 04-29-2009, 12:30 PM   #23
87 dually burb
my short bus
still waiting on my welder to get them done
Old 04-29-2009, 09:42 PM   #24
87 dually burb
my short bus
took them to local guy
fully welded around
wrapped the end with 3/16 strap
not bad for $150 steel/welded
Old 04-29-2009, 10:39 PM   #25
72 CustomCamper
huh ???
That's cool. Are you going to have it ready for the cruise in Saturday if it doesn't rain?
Chuck
