Old 10-01-2009, 10:37 AM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
cheap adjustable panard bars!!!
being as cheap as I am here my newest idea just need to run to tractor supply..ok I'm going to steal one off the tractor and see for sure first....I'll keep yea posted??
http://www.tractorsupply.com/agricul...gory-1-0267759
pretty hard to beat for $20 even if you had to tack weld it when you got it where you wanted it??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-01-2009, 10:38 AM   #2
Hottrucks
Hottrucks's Avatar
Re: cheap adjustable panard bars!!!
sorry posted in te wrong area should have been in general
MY BAD
Old 10-01-2009, 06:31 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
I would be skepticle about the quality of the rod ends.
I pay more than $20 per rod end for the style we use.... and that's with my WD discount.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-01-2009, 06:47 PM   #4
Hottrucks
Hottrucks's Avatar
I cut my stocl one today and added enough to stop my wheels from rubbing...Sunday there's haf dozen of us going for a ride and we drive by TS I looked at the one I have and it's to BIG around but I thnk they make a smaller one for smal tractors so well see I figured a good old farm boy would know better......I dont think there would be to much issue with the ends these things pick up a 1000lbs over and over again which is more than the lateral load of a panard bar...
Old 10-01-2009, 06:54 PM   #5
mbgmike
I would not use that. Its just to keep a brush hog or implement from swaying at slow speeds.
I have wondered though would the adjustables off the later Impalas fit?? they look like the might.
mbgmike is offline   Reply With Quote
Old 10-02-2009, 05:31 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Im with you on the ends not being the best quality, & they will most likely make noise & possibly wear out sooner than good ones
Actually that is the top link for the 3-point hook up on a tractor & it carries a fair amount of the load, so they are pretty strong & strong enough for this application IMO, just not necessarily the best choice
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-03-2009, 11:10 PM   #7
DHPmike
DHPmike's Avatar
Theres no jam nuts on those and they will rattle like crazy.
DHPmike is offline   Reply With Quote
Old 10-04-2009, 09:46 AM   #8
Hottrucks
Hottrucks's Avatar
the one on my tractor has a jam nut..and whats one more rattle...lol
Old 10-04-2009, 10:01 AM   #9
DHPmike
DHPmike's Avatar
You are much better off getting a panhard bar kit or getting some heims and a threaded rod and jam nuts. look at speedwaymotors.com. they have heims in several levels of quality and they have threaded rods in all lengths in 1" increments. They also have poly bushing ends that will also fit the threaded rod. They have the jam nuts in left and right hand threads and even weld on tabs.
Old 10-16-2009, 04:27 AM   #10
OARNGESI
OARNGESI's Avatar
Ever try this
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-16-2009, 07:50 AM   #11
Hottrucks
Hottrucks's Avatar
funny you ask... I finally made it to tractor supply...very kool store full of stuff...anyway I did check out the upper links and like anything else the ends come in a couple of dif qualities....took some measurements and yes they will work they even have a lock nut...
now did I get it well I cut my bar added 3/4" to it and am running it...even at $20 adjustable is a relitive term...truth is your going to put it on adjust it once then leave it.... I still think a watts link is the only answer to tracking correctly with Bags...theres just to many veriables on the up and down
