Old 02-05-2010, 03:46 AM   #1
O Papa Mo
Morigeau
O Papa Mo's Avatar
R & R a TH350 outta of a 69 C10
So planning on R&R'n a TH350 on my 69 C10... while on jack stands/blocks... It's about 2 feet of the garage floor... I was planning on using a tranny jack... am I gunna run into clearance issues trying to yard it out from under the truck once out and on the jack? What would be best... short of putting it on a hoist or pullin the whole eng & drive train in one piece?
Morigeau
O Papa Mo is offline   Reply With Quote
Old 02-05-2010, 08:00 AM   #2
junkyardjohn
junkyardjohn's Avatar
Re: R & R a TH350 outta of a 69 C10
I've ran into that problem myself several times. I even have a cradle that fits on my floor jack, but the truck would have to be jacked up about 3' to make it work. I usually just slide the tranny off the jack & onto the ground , then slide it out from under the truck. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-05-2010, 01:38 PM   #3
57larry
2 guys and a floor jack is all you need. done this too many times. I have a tranny jack but you have to have the truck about a mile high to use it...floor jack is fine
57larry is offline   Reply With Quote
Old 02-05-2010, 07:22 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I usually remove it from the tranny jack and onto some cardboard or an old moving blanket, then drag it out. Aim it so that the bellhousing comes out the wheel well opening.
Don't forget to support the engine under the oilpan. I use a short (9 inch or so) 2x4 and a bottle jack. If you don't do this, then the engine will want to roll back, and place the weight on the exhaust system. If you have old manifolds, it can, and almost certianly crack/break them.
Old 02-05-2010, 08:06 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I think all the advice these guys fed you is spot on!
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-23-2010, 12:37 AM   #6
O Papa Mo
Morigeau
O Papa Mo's Avatar
Thanks guy's... the floor jack with a length of 2x6 bolted to it did the job.... but now I can't remember how the shift bracket hooked up to the tranny
