vortec head ?
i have a set of 906 vortec heads i am going to run on my 350. my cam lift specs are .479I .465e. will these heads work with new springs or will they have to be machined?
Re: vortec head ?
I think you can run comps beehive spring with no problems but I would take them to a shop and have them check before you put it togather and tear something up.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
60-66 Nut
Re: vortec head ?
I have run a similar cam in an engine with Vortec heads that were upgraded to the 981 springs with no retainer to guide/seal issues. However you should always check your particular combination for proper clearances.
![]() Join Date: Apr 2008
Re: vortec head ?
Are you running flat tappet or roller cam? It may make a difference, factory vortec springs are light pressure for rollers.
79' Big Ten 70' 1 ton 4x4 LB "Mean Green" 70' SWB "Major Project" 69' El Camino "t-boned by Camry" |
Re: vortec head ?
i am running a flat tappet cam. i am not running the stock springs. i bought the springs recomended for this cam.
![]() Join Date: Jan 2010
Re: vortec head ?
