Old 05-28-2010, 02:07 AM   #1
profe56
disc brakes for chevy 56 1/2 ton
How can be converted drums into disc brakes chevy 56 1/2 ton.
thanks
profe56 is offline   Reply With Quote
Old 05-28-2010, 02:18 AM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: disc brakes for chevy 56 1/2 ton
Pretty much any one of the old truck vendors offers at least one kit to do this on the front. You can choose either 6-lug or 5-lug. The kit is basically the same for '41 through '59.
You need to also convert to dual master at the same time and generally you'll need to replumb at least part of your brake system to make it work.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 05-28-2010, 09:49 AM   #3
mbgmike
You can buy complete kits or just the brackets and put it together with parts locally purchased. Most of the kits are for 15" wheels minumum
mbgmike is offline   Reply With Quote
Old 05-28-2010, 10:15 AM   #4
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Lmc has a kit.mbgmike where can you get just the brackets. What year rotor and calipers do you use.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-28-2010, 12:30 PM   #5
raycow
Most of the kits that keep the stock spindles use Camaro/Chevelle or G-body rotors. You can buy the calipers and mounting plates separately. The difficulty with these trucks is that there is no stock inner bearing which fits the spindles. That's why the kits come with special bearings and spacers. Alternatively, you can machine the spindles and then use the common (and cheap) S-6 inner bearing sets.
If you want to run the larger (12 inch) rotors, I am pretty sure you will need aftermarket spindles.
Ray
raycow is offline   Reply With Quote
Old 05-28-2010, 07:21 PM   #6
mbgmike
Ray
Yes you need the bearing kit. Thast availible seperate also.
Old 05-28-2010, 07:19 PM   #7
mbgmike
We sell them. We sell all kinds of brake stuff for almost every vehicle.They are availible many places. from US, SPeedway motors, MPbrakes, and others
usually less then $100.00
