03-25-2002, 05:22 PM | #1 |
hei question
I've been reading alot of posts about hei,i guess i should have printed them out,there is two connections one that says tach and one that says batt,do i just make up connection from batt to fuse box and leave tach connection alone?
Springvale,Maine 71 3/4 GMC lwb |
03-25-2002, 05:27 PM | #2 |
You want the power wire on the accesories so that its only on when the ignition is in run.
Best way to do this is run a wire with a male spade onthe end to the fuse panel and just plug it into an empty hole marked "acc". The tach plug you leave unless of course you have a tach . Make sure to use a good wire, its the only thing keeping the truck running. Good luck. CoryM ------------------ 1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
