Old 12-10-2010, 09:58 AM   #1
Dads69C10
Dads69C10's Avatar
grinding?
Hello,
Im hoping for some help. I have a 73 K5 that started making a grinding sound. I hear it coming from the driver side front but who knows. I inspected and repacked the bearings and changed out the brake pads(worn but not terrible). I dont know much about 4X4's so im looking for other things to check out. thanks for any help
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline   Reply With Quote
Old 12-10-2010, 11:25 AM   #2
Transformula
Transformula's Avatar
Re: grinding?
Grinding sounds can travel all over a truck from the source sometimes. We need to know a few things first. Is the noise consistent with road speed or engine speed? Is it tied to acceleration/load or coast, or "float" conditions? Straight ahead or turning? If you know the exact conditions when this happens,, that can help narrow it down! There's a lot of things that can grind on a 4x4. I had driveshaft splines make a grinding sound under Float conditions once (Not under load, not coasting, but in between).
Transformula is offline   Reply With Quote
Old 12-10-2010, 06:14 PM   #3
Dads69C10
Dads69C10's Avatar
Re: grinding?
Ive only heard it under slow speeds. Thats only because i brake and stop as soon as i hear the grinding. I should note that the front drive shaft was taken out by the previous owner so i may have destroyed the NP203 by now. The grinding usually occurs duirng light acceleration and coasting straight ahead. Turning hasnt been an issue. Thanks again.
1969 C10 stepside
Old 12-10-2010, 08:52 PM   #4
Transformula
Re: grinding?
If it's coming from the case or rear axle usually you can hear or feel it through the shifter for the case. If the 203 has a part -time kit installed, then it won't get fried just by removing the front shaft. Slow speeds can be a wheel bearing, ring gear carrier bearing. Under light load or float/coast could be play in the rear shaft splines, bad case output bearing, too much play in the rear end, even a u-joint going bad. A wheel bearing won't care if it's under load or coasting.
Hopefully this gives you a little bit more to go by!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
