60 clutch/brake master cylinder to 65 brake master cylinder question
Ok So I am cab swaping.....I think I have most everything figured out except the brake master cylinder. The 60 keeper cab has the hydraulic clutch and brake master. The 65 just has the brake master cylinder. I have an automatic in the keeper truck, so no need for the clutch. Question is, can I take the brake master cylinder off the 65 cab and mount it up to the 60 and still work without a whole lot of modifying? probably just redrilling holes, just wondering the ease of this or if it a whole separate project in itself?
thanks ! J
1930 Olds 5 Window Coupe 1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350 1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!" 1966 Toronado 1971 Cutlass 1972 442 1978 Chevy 1/2 Long Fleetside 2001 Dodge 2500 |
1961 crewcab
Re: 60 clutch/brake master cylinder to 65 brake master cylinder question
this thread might help, check out the last post too, you might need to do some modifying..
http://67-72chevytrucks.com/vboard/s...d.php?t=355711
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#3 | |
He makes this part which I installed just 2 days ago, to cover the 2nd. hole and re align the bolts.
http://s1299.photobucket.com/user/jb...23904108567829 |
Sweet thanks !!!!! Are you using the original brake cylinder from a 63-66?
1930 Olds 5 Window Coupe 1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350 1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!" 1966 Toronado 1971 Cutlass 1972 442 1978 Chevy 1/2 Long Fleetside 2001 Dodge 2500 Last edited by 65stepside; 03-03-2011 at 10:54 AM. |
No, my donar cab was set up as a 4 speed so since I had the hrdramatic mated to the block, I needed to close off the extra hole. on the BB they say use a '67 impala? dual master cylinder whoch mates right up the original holes.
Someone chime in on what years he can use, I'm not sure. jake
#6 | |
60-66 Nut
Most any GM master cylinder will bolt up. For manual drum/drum brakes I prefer to use the '67-'70 master cylinder and metering block. For manual disc/drum brakes , use a '71-~'76 master cylinder and proportioning valve.
