03-25-2011, 11:21 AM | #1 |
1988 350 TBI idles funny, stalls when put in gear, and accels rough...
So for the questions:
1) Service engine light didn't come on until after 5-10 mins of driving (no faster than 45 mph). Without reading codes yet, any gut suggestions (perhaps better answered in conjunction with #2...) 2) It won't accelerate smoothly. It will start out SLOW and smooth until about 15-20 mph, then it wont accelerate worth a flip for a few seconds (no change in pedal pressure) before acting like it starts "catching" and resumes accelerating. Very consistent doing this, so essentially I can't take off at all. 3) It had a tendency to stall when I first test drove it, easily overcome with very slight pedal pressure when at a stand still. I made it home a 15 min drive without stalling this way. Could be related to #2? It idles well enough it seems, but it's been sitting for almost 2 years, with being moved around the lot once a month or so during grass cutting season. Hoping bad fuel might be part of the problem, i put 18.5 fresh gallons in it with a bottle of the Techron fuel system cleaner right as I started the drive home. I didn't let it just sit at a light in gear, not wanting to risk it stalling in the middle of the road so im not sure if it made any difference on the way home. I'll stop there, as those are my primary concerns right now (getting it running well). Thanks for looking. I intend on new plugs/wires at a minimum today, and checking the timing. If it doesn't clean up, what about fuel filter and EGR valve? -Trey
My vehicles: 2003 Saturn ION 1 1988 V10 Suburban 4x4 Dad's: 68 C10 Stepside (work truck condition, runs though) 59 Apache Fleetside (rusted pile of metal - hopefully soon to be father/son project when he cleans out his garage!) Can see all three of these here Last edited by irongun324; 03-25-2011 at 11:22 AM. |
03-25-2011, 01:24 PM | #2 |
Junior Member
Re: 1988 350 TBI idles funny, stalls when put in gear, and accels rough...
The engine may smooth out as you drive it some, but I would also change the oxygen sensor.
Auto Zone and O'Riellys will run a code check for you. Sometimes it depends on which O'Rielly's guy you talk to because the one I worked at had a policy not to run codes just to loan the code reader. Usually if you went there after 6:00 pm we would run the code.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-25-2011, 03:56 PM | #3 |
My guess would be oxygen sensor or fuel filter. I had a bad egr valve and my symptoms were normal idle, off idle acceleration would lope really bad almost like blower surge and it would go away as it accelerated and if you let off it would make a weird sound then go back to normal idle. I found out it was the egr by unplugging the egr connection completeley, its on the passenger side of the intake manifold possibly touching the valvecover about in the middle, unplug it and if it runs normal its your egr but i suspect o2 sensor or fuel filter. good luck
1979 C10 - swb, mild 327, restoration project 1979 Mustang - Turbo 5.3 / 4l80e 1976 K20 - Mild 396, 6" lift, 35's - sold 1986 C10 - lwb vortec 355- sold 1982 C10 - swb project- sold |
03-25-2011, 07:19 PM | #4 |
Check fuel pressure - if you have original fuel pump the chances are that either FP is tired or fuel hose between FP outlet and feed through is leaking.
Codes can be read by inserting a jumper between pins A&B of ALDL and reading the number of blinks of SES light. Insert jumper, turn ignition on, without starting engine. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
03-25-2011, 08:27 PM | #5 |
I checked the code: 44 was the only one, Lean exhaust right?
I went and grabbed some plugs/wires as a good start, and went ahead and got a new fuel filter. I figure that can't hurt after sitting for that period of time. I'll go from there... updates soon.
My vehicles: 2003 Saturn ION 1 1988 V10 Suburban 4x4 Dad's: 68 C10 Stepside (work truck condition, runs though) 59 Apache Fleetside (rusted pile of metal - hopefully soon to be father/son project when he cleans out his garage!) Can see all three of these here |
03-26-2011, 12:37 AM | #6 | |
//RF
03-26-2011, 10:21 PM | #7 |
Well it "seems" better, as far as idling goes. Definitely still no throttle response though. Even just trying to rev the engine in park, it's not smooth.
Any suggestions on ways to test other things: diaphram, spring, or just fuel pump altogether? I'm assuming I have to drop the fuel take to get to the pump? I see no access panel inside the back.
03-27-2011, 01:34 AM | #8 | |
//RF
04-03-2011, 10:07 AM | #9 | |
Besides obvious damage (hose/filter inside the tank being shot), what else can I do? On another note, could it be that the engine warming up is warming up the ignition coil also? Kind of a random though this morning
03-26-2011, 10:46 PM | #10 |
did you try to unplug the egr?
Fuzzy |
04-02-2011, 09:34 PM | #11 |
Well now that I finally could test fuel pressure.... Im getting less than 8 psi at the throttle body. So bad pump? Or could it be grounds?
04-03-2011, 12:42 PM | #12 | |
1) Bad or tired pump (after 20+ years in service it is done). 2) Burst in the fuel hose between pump outlet port and tank sending unit. 3) Low voltage at the fuel pump terminals. (Should be around 12.5+ Vdc with engine running at the tank terminals) Most of the time it is 1 & 2 with #2 causing #1. When you get a replacement pump make sure to replace the hose with SAE30R10 - fuel submersible rated fuel line. Do not use commonly available 30R7 or 30R9. Most pumps kits come with fuel hose supplied - it should be the correct type. If you pump kit is missing this hose you can get it from Napa - 3/8" ID part number H213 (Gates 42196184). Kragen and Autozone do not carry, unless special order. //RF
04-03-2011, 01:49 PM | #13 |
I rebuilt the FPR with the Autozone kit, which included a new spring and used the new spring. Either way this is without taking the FPR into account, I was measuring at the inlet, fuel line disconnected and plugged into a pressure gauge (dont have the materials to make an inline one yet).
Autozone has a fuel pump rebuild kit, that doesn't include strainer for 54, or I could order THIS from Rockauto. Thoughts? I don't really have the budget to spend 150$ on a new whole assembly, especially if I don't need to. The gas gauge seems to be working fine for example. I'm just looking to keep it ticking, for occasional use as a work truck.
My vehicles: 2003 Saturn ION 1 1988 V10 Suburban 4x4 Dad's: 68 C10 Stepside (work truck condition, runs though) 59 Apache Fleetside (rusted pile of metal - hopefully soon to be father/son project when he cleans out his garage!) Can see all three of these here Last edited by irongun324; 04-03-2011 at 01:53 PM. |
04-03-2011, 03:27 PM | #14 | |
OK - you have performed a dead head pump test - a good TBI pump should deliver 20+ PSI. You have a bad fuel pump partner! Rock auto kit is a good replacement kit and has the right hose included. Inlet strainer should be replaced as they get clogged over time (time is our enemy!). Please note since we live in CA our fuel (oxygenated, skunky smelling poop) and contains 10 to 15% ethanol (depending on refinery). This stuff is bad news for older vehicles - anything designed and built before 1995 or their about. You should thank Air resources board for this one. //RF //RF
04-03-2011, 04:40 PM | #15 |
Ours is usually 10% here in Alabama. I heard there is a anti-ethanol additive for older vehicles, any suggestions?
05-08-2011, 11:33 PM | #16 |
Fixed!
After rebuilding the fuel pressure regulator, new fuel filter, plugs and wires, I finally dropped a new fuel pump in and seems to be running like a champ. Posted via Mobile Device
05-10-2011, 07:39 PM | #17 |
You might have a bad MAP sensor. It is cheap and it is THE main sensor the controls the fuel mixture off idle.
05-10-2011, 10:06 PM | #18 |
Perhaps, but for now it is running very strong. No codes, and no hesitation. Even starts too fast now!
05-11-2011, 01:26 AM | #19 | |
//RF
01-21-2015, 02:18 PM | #20 |
I have a fully restored 1991 Chevy Suburban that has fresh engine transmission rear end paint interior and I have left nothing undone or unrefreshed.
About 3 months ago it quit running cold in Houston and had to have it towed back to Dallas. For all parts below I acquired all parts thru O'Reillys Auto Parts. Hereth begins the diagnostics, no CHECK ENGINE LIGHT was produced. Similar issue occured 3 years ago on an older engine ,same truck. At that time it was a bad EGR VALVE. I had bypassed the vacuum source and it ran fine. So I replaced with AC DELCO EGR Valve and that fixed the issue. That was then this is now!!!!!!!! So isolating the EGR did not fix it this time. Symptoms are: starts, runs fine, until warmed up and then the engine will lose all power and act as if its starving for fuel. Starting there the original tank had broken plastic windage tray baffles in it so I replaced the fuel tank with new tank and replaced with a new pump and hanger assy. No change. Next, took the car to local Chevy Dealer that has several old school techs still working. After running their tests they figured the ECM was failing. So I purchased a reman'd unit thru O'Reillys Auto Parts. Swapped the CAL unit and reinstalled it. No change. Forget the dealer, they were useless. Next, read when MAP sensor can cause this similar condition, replaced MAP Sensor. No change. Next, replaced EGR, EGR sensor. No change. Next, replaced distributor. I had found traces of surface rust on reluctor on distributor shaft so pickup coil maybe effected. New distributor comes with new ESC electronic unit, pickup coil, cap & rotor, also. No change. Next, read somewhere that the fuel pressure regulator diaphram if split could cause flooding. rebuilt throttle body unit, rebushed it and boiled it out and added rebuild kit and brand new Borg Warner injectors. No change. Next, read somewhere that Engine Oil Pressure sender (behind and below the distributor) since it serves and oil pressure guage sender and fuel cutoff switch in case of loss of oil pressure, replace it with new to eliminate that. No change. Next, read somewhere that bad ground wire on Thermostat housing can cause ECM issues. Checked it, cleaned it off, verfied that contact wanhers are all steel and attract a magnet, reinstall the ground wire. No change. Next, read somewhere that Engine Coolant Temp Sensor if malfunctioning could cause the ECM to think the engine is at -40 deg F in dflt mode. This would make the IAC Valve stay or go closed as if engine were in cold start mode. This would cause flooding since the injectors are receiving signals from the ECM that its a cold start so needs little air and lots of fuel. Replace dhte driver side (left side) Coolant Temp Sensor (1 wire pigtail) unit. No change. BUT BUT BUT, I forgot that there is a 2nd Temp Sensor (2 wire pigtail) unit mounted very front of intake manifold just to the front of the thermostat housing area. I pulled it and replaced it. BINGO!!!!! Problem resolved. Now I know why ODBI only lasted a couple of years. Its all about luck. Yes..... if I had started with the coolant temp sensor first I would have gotten off cheap. But all items replace can potentially cause this symptom. |
01-21-2015, 03:00 PM | #21 |
I had an issue similar to that with my 89 Jimmy. It would also just die once in a while while idle.....Turned out to be one of the injectors on the throttle body was shorted. The way I found out was kind of a bummer but I found it......
On the way to work one morning at 5 AM it started in on me, sputtering and stalling. It would restart each time it died and run great for a while. Finally I prayed Lord, please help me to find this problem. It is really getting on my nerves. Just then.....it died and wouldn't restart. I cranked for about 5 minutes. No go. The injector had finally fried the power fuse for the injectors. Called AAA and drove another car to work. Replaced both injectors and the fuse....OFF I GO!! No more issues. Moral of the true story, be careful what you pray for.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-21-2015, 04:03 PM | #22 |
OLDS
The fact that you had never seen check engine light on should have been investigated before any parts were replaced. The two wire CTS sensor failure is readily detectable when Pins A & B of ALDL connector are jumpered and functioning SES light would have blinked 12 12 12 15 15 15 - repeating. OBD-1 system was primitive by today's standards, but it does the job even today. CTS circuit Short circuit between the two pins will result in DTC 14 which equivalent to coolant temperature sensor signal indicates a temperature of over 275° F for 2 seconds. Unplugging CTS will result in DTC 15 - coolant temperature sensor signal indicates a temperature colder than -27° F for 30 seconds after the engine has been running for at least 30 seconds. Service techs failed to verify SES functionality during POST - burnt out light bulb can be misleading! This is the basic check of any EFI system, when turning ignition key into ON position. You simply have to follow this basic troubleshooting flow chart to avoid needless parts replacement. //RF
