How can I bypass the neutral safety switch?
Hey guys, my truck's (1988 c1500 4.3 w/5spd) neutral(or clutch?) safety switch has been acting up since I beat the hell out of it trying to bleed the clutch master cylinder and I was hoping to just bypass it. Can I simply join the wires to complete the circuit or does it need something else? My truck has the purple and yellow wires to the switch if it matters. Thanks guys!
If all men are created Equal* does that mean we are all artifical?
One day...
Re: How can I bypass the neutral safety switch?
If the switch is normally open and when you press the clutch it closes the circuit then just wire them together. Just be sure everyone knows that it is like that... I had an auto start on mine and had to be sure to leave it in neutral and luckily i never had any accidents and probably wasnt the brightest of moves
#3 | |
One day...
Ya it looks cool on someone elses car when it tries to start for 30 seconds and waits a few and does it again
#5 | |
![]() Join Date: Sep 2004
Anyway...I think the switches are adjustable. But otherwise Im sure they are really cheap and definitely a good idea too have, especially if anyone else ever drives the truck.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
Just buy the switch and fix it correctly.It's there for a reason,and the fact that it MIGHT keep someone from getting hurt or killed is all the reason you need to justify the cost.
RIP Baby Jack 2-06-07 See You On The Other Side My Little Man |
I have no plans to add a remote start to the car at this point. And I am the only one who ever drives my truck now-a-days. After getting it damaged in minor ways the last two times I borrowed it out, I learned my lesson.
![]() I'll join the wires and see if that does the trick.
I joined the wires on my '87 f150, no problems.
Josh 1978 RCLB K20, Built 400 SBC, SM465, Lifted 1994 RCSB Silverado, 375HP 350, TH350, 4/6, Toy |
laying low
![]() Join Date: Mar 2001
Cause: [safety switch has been acting up since I beat the hell out of it trying to bleed the clutch master cylinder ]
Hey many of us have been to that point ya know. But why not fix it the right way and replace the bad switch? It's there for a real good reason. If not your own safety then someone else's. You think you will be the only one to drive it but how bout the guy you sell it to or the garage that works on it or a friend helping you boost it off. I know a man who got both his legs broken when standing between cars while boosting one off. It was his daughter who turned the key. He was in the wrong place but point is it happened. I'm not slammin you for wanting to save a buck but these switches are normally less than 20 bucks.
I understand what you guys are saying, and I will be replacing the switch, but payday is still a week off and I have to have a truck that can start and enough money to eat. I'm a poor working man and when you only have $25 bucks in the bank to last a week for food and gas, $12 is a lot of money.
What is important to me right now is getting to work reliably for the next 5 days and if jumping the wires so that happens is what I need to do, then I will do it until I get the switch. You guys need to remember that sometimes people can't afford even a $12 part. Haven't any of you guys had to make temporary fixes just to make it until you could fix it right? So anyway, thanks for the help Orangette and scotts62. I understand where the rest of ya'll are coming from and I know you mean well, I just can't get that part yet. I'll let you guys know once I replace it! Cheers!
