landarts
![]() Join Date: May 2005
Project: Fixrupr 72 Cheyenne
This is the beginning of my 72 cheyenne long bed build thread. Should have started this long ago, however I have pictures of most of the work done up until now. FIXRUPR is what I'm calling this truck because it seems that's what I'm always doing is fixin it up. Also that is what my personalized plates will say on them......
I purchased the truck about 8 to ten years ago when I lived in Arizona and brought it with me when I moved to Idaho a few years ago. Didnt really do much to the truck while i had it in Arizona. Just start it every now and then and give it a drive maybe once every couple of months. Once I got moved up to Idaho and got settled in I was kinda forced into making it a daily driver due to financial situations. I really didnt mind that because it is fun to drive and I always seem to get someone that is making comments about the old truck. makes for a great conversation starter. This build thread is not a frame off, more of a fix whats wrong, change it the way I like it build. I will be doing all the work myself and some guidance of a few seasoned friends. I have been collecting items for the truck for the last year or two. Like the following. PICTURE will go here
Oh yeah I forgot to mention I have a problem collecting these trucks, as for now I have 7 trucks.
Re: Fixrupr
Looks Great!
Re: Fixrupr
nice craftsmanship landarts!
project: "my happy mess" |
landarts
Thanks for the props. Its been a learning experience.
landarts
Here is a picture of the product I used to bring the rusty nuts and bolts back to life. I believe I bought evapo-rust at Harbour Frieght for $20.
I would take nuts and bolts from the marked ziploc bag and put them in the solution over night, then take them out rinse them off and them I had a scrap piece of 2x6 with holes drilled in it. Inserted the bolts and sprayed with single stage gloss black. Last edited by landarts; 08-06-2011 at 12:33 PM. |
landarts
Here are a few pictures of some of the previous repairs done by the P.O.
I completely striped down this rear corner and reworked with a hammer and made some structural welds then refinished with minimal filler. The gas tank patch they had done was a square plate from the backside - then they filled with filler which cracked. I removed and cut a new template and piece of sheet metal to be butt welded from the outside. Last edited by landarts; 08-06-2011 at 12:34 PM. |
landarts
Well today I turned over the keys to my 16 year old son for his first truck. He got his license about 10 days ago. He is now the proud owner of a 1967 lwb c20. The truck has all the original items that were on it when it was bought here locally. A 327 motor that really runs great, stock radio, etc. No rust and not all dented up. Once I finish the paint on the 72 FIXRUPR in the next week or so, we will be rolling the 67 in for body and paint.
We have a set of 8 lug ralleys that we are getting ready to blast and paint, then get some smaller tires for his ride. Check back latter and I will post a few pictures of the truck when he returns from the river. After he saves up a little more money we are going to drop it and put disc brakes on the front. Last edited by landarts; 08-06-2011 at 12:34 PM. |
Hotrodchevy
Re: Fixrupr
Looking good
2017 1500 CREW CAB GMC 1997 C1500 Chevy 1971 CHEVY CHEVELLE SS 402BB : 1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816 My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650 |
landarts
Re: Fixrupr
This morning I finished shooting etching primer on the hood and tailgate. After all has dried I will be shooting filler primer this afternoon.
landarts
Re: Fixrupr
Found some rust in the drivers lower right corner. Here are a few pictures of the repair made with new sheet metal.
landarts
Re: Fixrupr
Here are the rest of the door repair - part 2
While I was at it I decided to grind down the weld that is from factory on the upper door frame and smooth with filler. |
landarts
Re: Fixrupr
Here are pictures from today of the 68 hood I plug welded the trim holes and letter holes. Added filler and etching primer.
landarts
Re: Fixrupr
Now on the list to get this truck ready for paint.
I need to do one more coat of filler primer and block sand the hood, front fenders, both doors, tail gate and grill. The cab needs one more coat of filler primer and block sanding, interior needs block sanding. Lots of sanding and lots of dust to go. Shooting for spraying the interior in one week along with inner doors, hinges. |
landarts
Re: Fixrupr
Took the time to tear out all the door insides so i can clean them up and service them. While they are out I will 3m undercoat the inside of the doors. Had a hard time on both doors getting the screws out of the door strike tumbler assembly. After soaking with PB blaster and having no luck I finally took a bolt and welded it to the screw and was able to get them all out that way. All of the other screws came out with out any problems. Pictures to follow.
#15 |
landarts
Re: Fixrupr
This picture is for Craig - Picture of rear axle on the 67 C20.
#16 |
landarts
Re: Fixrupr
Picture from above was from my sons truck. He had a driver side rear wheel seal leaking. With a little guidance from "Craig" I was able to take the drum off and get a new seal installed. Had to completely remove all brake items and degrease. It looks as if the brakes were brand new...just covered with axle oil. Got everything all back together and working.
#17 |
landarts
Re: Fixrupr
Well finally got the tilt column, driver door and tailgate shot in filler primer today. Will probably remove from wires and hang up other door and hinges for another round of primer this afternoon.
#18 |
67cheby
![]() Join Date: Sep 2008
Re: Fixrupr
looking good !! did you ever get a chance to come up with me a quote for my website
#19 |
landarts
Re: Fixrupr
67cheby I just sent you a PM about the website.
#20 |
landarts
Re: Fixrupr
Here are a few pictures of round two with the filler primer and finally getting to start the wet sanding.
#21 |
landarts
Re: Fixrupr
Did some shop cleaning today and built my second set of body panel stands. I had some left over 3/4" conduit and miscellaneous hardware. So I grabbed the tube bender and went to work on throwing another one together. Probably not the best in the world but its sturdy and I had the left over material.
#22 |
landarts
Re: Fixrupr
Here is a shot of the next items up for second round of wet sanding and the hood getting the underside primed. With any luck I might be ready by the end of the week to start shooting color.
#23 |
![]() Join Date: Feb 2011
Re: Fixrupr
Looking good mate. Keep it up I'll be watching this one. Cheers
Posted via Mobile Device |
#24 |
VA72C10
![]() Join Date: Mar 2008
Re: Fixrupr
very nice build. Great work and it's coming together nicely.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#25 |
landarts
Re: Fixrupr
Hey thanks for the props. Its been a fun long project. Mostly the body work I had to do to get it to acceptable standards.
So far here is a list of what i have done so far. Removed entire front clip - replaced with a 68 entire front clip On the 68 clip I welded in all the lettering holes, repair a small tear in the front drivers side fender, did some dolly and hammer work, filler work primer and under coating of the front fenders. The cab - No rust to repair! Cut out out filler patch for gas tank welded in and filler, welded in back of cab trim holes and filled, removed everything from the cab, including all interior items, doors, hinges etc. Doors - removed all internal hardware and windows, did some dolly and hammer work, welded in mirror holes, welded in a rust patch at bottom of door, filler work. Bed- No rust repairs needed, cut out sheet metal to patch where the auxillasry tanks were, dolly and hammer work and filler. Hood - was in excellent shape, welded in the letters and trim holes, minor filler work and the most time spent on the dip in the middle of the hood crease. Found the best way was to form a piece of hard oak that would fit the shape of the contour under the hood and start beating on it until it finally submitted. I know there has been much more to than stated above, but at least it gives a good documentation of the basics so far. As of now just about every part on truck that is going to get paint has 2 coats of filler primer, I use the Napa crossfire cp440. Sand great and fills sanding scratches well. I am now working through the wet sanding process so I can get it ready for sealer and paint.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
