Old 08-04-2011, 07:33 AM   #1
towieguy
454 366 bbc
hi how do i tell a 366 from a 454 .
i have a 454 but never seen a 366 but to rego my chev here in the land down under it came out with a 366 so how do i tell or make my 454 look like a 366
towieguy is offline   Reply With Quote
Old 08-04-2011, 10:04 AM   #2
Redcap
Re: 454 366 bbc
Forged crank, stroke of crank.
I'm sure there is something I'm forgetting....
Redcap is offline   Reply With Quote
Old 08-04-2011, 10:59 AM   #3
stich626
Re: 454 366 bbc
taller deck
stich626 is offline   Reply With Quote
Old 08-04-2011, 12:19 PM   #4
royo
royo's Avatar
Re: 454 366 bbc
Can you get the number off the back of the block? Otherwise it will look the same
nickle and dime
royo is offline   Reply With Quote
Old 08-05-2011, 06:36 AM   #5
D13
D13's Avatar
Re: 454 366 bbc
366 is a tall deck, .40 higher on the block per side, allowing room for 1 extra piston ring. These were not used in 1 ton or smaller, strictly a big truck motor. 454 has balance weights on the flywheel and harmonic balancer. 366 crank is high quality and the same as 396/402/427, 454 is different. 366 has the smallest bores of the BBC's. If this is a big truck the 366 probably has cast iron headers. They tens to use 4bbl spreadbore Holley carbs, often with speed regulators.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 08-08-2011, 01:48 AM   #6
rickpilgrim
Re: 454 366 bbc
On my 1977 C50 366 is a tall block engine, uses a wider intake manifold with 2 thermostats, has exhaust manifolds that cannot be used with clamshell motor mounts,will not have vac adv on distributor. Has an extended snout on the balancer with 6 bolt holes for the pulley set. Holley carb with either vacumn or electronic connection to the distributor and accessory brackets that are lower (PS) and higher (alt/ac) than you can use on a 1 ton or smaller truck. Also the oil pan would be much larger capacity than the 454.
366 should all have forged crank, good rods and 4 ring pistons. In as much as a 366 looks like a 454, the intake manifolds won't interchange without spacers so you always have 2 thermostats and the way they fit in the 10/20/30 series trucks I can tell if it's a tall block or passenger use engine and many others can also. The 427 TB I'm putting in our 93 K3500 dually is alot closer from valve cover to hydro boost brakes and AC condensor than the 454 would be, and in total height from oil pan to top of carb is very close to a 500 Cad with the Performer intake.
rickpilgrim is offline   Reply With Quote
Old 08-08-2011, 07:18 AM   #7
towieguy
Re: 454 366 bbc
do the engine No:'s have prefix's for 454 / 336 ?
Old 08-08-2011, 09:10 AM   #8
Monty
Re: 454 366 bbc
my 427 truck engine has "TRUCK" cast into it above the oil filter boss. the water pump is a truck block only pump, and the distrubutor can either be a longer tall deck dist. or the standard V8 dist. depending on the age.
mine is going into a suburban 4x4. hopefully i can get p/s and alt bracketts to work.
Monty is offline   Reply With Quote
Old 09-19-2011, 04:25 AM   #9
Dooley
Dooley's Avatar
Re: 454 366 bbc
I recently got one of the 366's to replace the blown 6.2 in my M1008 CUCV.
It's now bored .60 over and I'm collecting the parts I need for the swap. An oil pan, water pump, exhaust manifolds, oil pump and pickup, motor mounts, fan/pulleys from a 454, new Dart intake manifold, and other assorted brackets and other items.
Dooley is offline   Reply With Quote
Old 09-20-2011, 07:12 PM   #10
68Gold/white
Re: 454 366 bbc
I'm assuming that Dart intake is for the tall deck block??? Not many make intakes for tall decks, and most are for racing applications. I have not kept up on what's currently available, though....
I was contemplating this swap, but it seemed to be too much trouble. I had the stuff for a low fan water pump setup (the high fan water pump, is TOO high), it solved the water pump bypass deal (using a stock intake) , but the larger size radiator hoses, inspired me to swap the engine (I got a deal on it) for some other stuff, I could use.
Keep us informed on this, you might have some ideas, the rest of us can use...366's were in school buses, and all kinds of medium duty trucks (although this stuff is getting more scarce every day w/ the high prices being paid for scrap these days).
The oil pan in the picture MIGHT work if it's a 7 quart pan, if it's a 10 qt. pan, no way...
I'm assuming you are not using the 366 balancer...
68Gold/white is offline   Reply With Quote
Old 09-20-2011, 09:45 PM   #11
SSC's76
No No
SSC's76's Avatar
Re: 454 366 bbc
found this on you tube granted not real informative but give a good idea of what a tall deck looks like in a newer truck. I seen my dad do a few tall deck installs on some cars and a few trucks granted i was 9 so i cant comment on the details but they make adaptors for short deck manifolds to fit usually about $120 but well worth it to address the cost of a tall deck performance intake ebay would be a good place to look. I remember mallory had a standard vac advance distributor that would replace the junk one these engines came with most likely it's still out there or since gm has a quite a few tall deck crate engines out there im sure a distributor without a slip collar could be dug up easy.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 09-22-2011, 10:07 AM   #12
100%Chevy
Re: 454 366 bbc
There are 3 talldeck engines-366,427 and 454.
I have a 427.
The easiest way for me to tell them from a regular big block is the distance from the top water pump mounting bolt hole to the surface of the blocks deck.
It's about 3/8" on a tall deck and even on a regular big block.
The actual difference is .4" as measured from the center of the crank to the top of the deck.
You can't over-rev a t.d.!(Well,you can one time!Then look for another one!)
Mike.
100%Chevy is offline   Reply With Quote
Old 09-23-2011, 06:10 PM   #13
68Gold/white
Re: 454 366 bbc
I have a 427.
Mike.
So the 454 in the 2000 and new medium duty trucks is a tall deck also???
I didn't know that......I assumed it to be a standard deck. That extra ring theory is an oldie......
Is the 495 (8.1) in Med duty trucks tall deck also???
Old 01-30-2012, 01:52 AM   #14
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: 454 366 bbc
Originally Posted by 100%chevy View Post
the easiest way for me to tell them from a regular big block is the distance from the top water pump mounting bolt hole to the surface of the blocks deck.
bingo!!!!
prostreetC-10 is offline   Reply With Quote
Old 09-26-2011, 03:24 AM   #15
Dooley
Dooley's Avatar
Re: 454 366 bbc
I have a new oil pan for it.
New standard BB water pump.
Nice set of original 454 exhaust manifolds.
New oil pump and pickup.
Dart 41215000 Tall Deck Oval Port Intake that uses the GM standard length distributor.
I have quite a collection of motor mounts, pulleys, and brackets now also.
Old 09-26-2011, 11:11 PM   #16
100%Chevy
Re: 454 366 bbc
68Gold/white,I don't know about the 2000 454's or the 8.1's.
I'm just into the older stuff!
By your name,I assume you have a 68 anniversary?
So do I!
Several shown here on the Mortec list:
http://web.archive.org/web/200805130...ec.com/bbc.htm
Mike.
Old 11-30-2011, 10:32 AM   #17
Dooley
Dooley's Avatar
Re: 454 366 bbc
The gasser switch from the diesel is underway!
Still gathering up items and working on he hookups. Trying to keep the 24v accessories intact.
Old 01-29-2012, 03:59 PM   #18
Dooley
Dooley's Avatar
Re: 454 366 bbc
Sorry for the delay of more recent pics! I managed to keep my 24v systems intact.
Old 01-30-2012, 01:54 AM   #19
prostreetC-10
My Carbon Footprint
Re: 454 366 bbc
I'm just curious why on Earth you would run an intake that starts at 4,000 rpm and a motor that stops there?
Old 09-10-2012, 09:36 PM   #20
Greasey Hand
Re: 454 366 bbc
I have a 366 in a 67 C-50 Chev & a 88 GMC with a 427 & need front motor mounts, You have some? 320-583-6901
Greasey Hand is offline   Reply With Quote
Old 09-23-2011, 03:34 AM   #21
rusty048
Re: 454 366 bbc
Why does it have to be a 366? Didnt know any came out in aus with them thought they werd all 292. Easiest is tell em its a 366. They dont know. Getting my C20 complianced and rego (this one LHD, all my others factory RHD), 9 outta 10 they took my word for it
rusty048 is offline   Reply With Quote
Old 01-30-2012, 01:24 AM   #22
GRX
GRX's Avatar
Re: 454 366 bbc
Back in the 80's there were a couple guys who used to bring 366's to my machine shop all the time. Back then a lot of school bus companies were scrapping their fleets and the 366 were everywhere. They did a fair job racing with them.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-06-2012, 09:26 PM   #23
chevy427big block
Re: 454 366 bbc
what alternator brackets did you use on the passenger side?
chevy427big block is offline   Reply With Quote
Old 03-06-2012, 11:19 PM   #24
prostreetC-10
My Carbon Footprint
Re: 454 366 bbc
At least I see a Holley on that thing!
