11-22-2011, 11:27 PM | #1 |
Grandpa in the rustmobile...
alternator wire...
I have an alternator with a stud comming off the back and 1 16 guage wire that runs to the battery.
1-Is 16 guage wire heavy enough for this??? 2-The battery has 2 prongs comming off it, I think one of the prongs has a wire going to the stub-I THINK, I'll check and try'n get pix. Thans
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-22-2011, 11:50 PM | #2 |
Msgt USAF Ret
Re: alternator wire...
Sounds like a one-wire alternator. 12 gauge is stock and 10 gauge is better. 8 gauge is better yet.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-23-2011, 11:25 AM | #3 |
Ok,
Where should this wire be ran to? (currently to battery, gfs dad tells me that jerry rigged lol)
11-23-2011, 01:57 PM | #4 |
16 gauge? seriously? i honestly cannot believe it has not caught fire like that yet. I always go overkill on wiring so i would go 4 gauge but 8 would be fine.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
11-23-2011, 02:42 PM | #5 |
Msgt USAF Ret
Here is the stock diagram. I have bypassed the horn relay because the trucks from 67 up moved it under the dash in the cab. In reality as long as it connects to the positive battery terminal it will charge the battery. Wiring it like the diagram will give better power to the accessories.
Here it is in real time. The wiring charts for AWG 12 show the amperage carrying limits for a given length of wire and for most applications it is enough. 10 gauge will give a smaller resistance and 8 less yet.
11-23-2011, 06:22 PM | #6 |
What do you recommend hooking it too (Battery,starter, other?)
11-24-2011, 01:01 AM | #7 |
Msgt USAF Ret
Hook it to the joint and here's why.
http://www.madelectrical.com/electri...esensing.shtml Not only that, but if you have an ammeter dash gauge then you will not be able to get the ammeter to work unless it is wired to the joint, so that there is a shunt between the battery and the alternator feed wire. I can get into this more but it can be a little technical. Can you provide more details on what system you have. Alternator type, internal or external regulator, type of dash gauge idiot light or ammeter and what wires you have. The 3 wire alternator SI conversions work better and provide more amperage output.
11-24-2011, 11:18 AM | #8 |
I am not trying to hijack this thread, but seems like a good place to ask a question. I am in the process of doing the internal conversion. I cut the blue and brown wires at the clip and crimped them together(from the FAQ section). I know this is going to sound stupid, but do I plug the clip back in on the rad. support? I try to follow steps as I read them, but it never says to plug it back in.
11-24-2011, 01:48 PM | #9 | |
Msgt USAF Ret
This picture shows the procedure. The brown and blue wires are not clipped together. The brown and white wires are clipped together and the blue and red are clipped together. Then the white wire is connected to the no. 1 terminal on the alternator and the blue wire is connected to the alternator at terminal no.2. The white wire is shown as black on the picture. Todd eliminates the blue wire connection by running a short jumper from the large stud on the back of the alternator to the no. 2 terminal. This will work but the picture way of doing it gives a more efficient voltage drop sensing to the alternator internal regulator. Then you can remove the external regulator on the radiator support and the clip will no longer be used. Most of the auto parts stores sell the rectangular white plastic plug that plugs into the alternator so you can splice the wires together and connect them to the alternator.
11-24-2011, 03:33 PM | #10 |
Msgt USAF Ret
Here's a picture of the conversion with the brown wire run all the way to the alternator and the blue wire replaced by the red jumper.
11-24-2011, 07:59 PM | #11 |
I'll have pix tomorow nite or friday of everything, thanks vette
11-25-2011, 12:22 PM | #12 |
The red wire is the 16guage that goes STRAIGHT to the (+)
11-27-2011, 02:29 PM | #13 |
TTT
So I need to run a 10 guage wire from the alternator to......??? Where should the power wire for the fusebox come from? Thanks you
11-27-2011, 03:34 PM | #14 |
Msgt USAF Ret
If you look at the picture I posted, The red wire junction is how the stock 67 truck is wired, it's mine. This is done so that there will be a shunt between the battery and the alternator for the ammeter gauge to read charge or discharge. The fuse block feed wire is also connected there and it runs to the firewall block and feeds the light switch, the horn relay, and the ignition switch as well as the fuse panel.
The alternator external regulator sensing wire is also connected to the junction. It's all in the diagram I posted in post 9. If you have a one-wire alternator then you can connect it to the junction and the ammeter should still work. If you have the idiot light then it will not work because it is no longer connected to the alternator field circuit and the diode trio inside the alternator, to indicate the alternator output or the battery state of charge. If your truck has been converted to the internal regulator alternator and it's a one wire, Then you can just connect the gauge wire you choose to use from the stud on the back to the junction or to the battery plus or to the starter terminal. The picture you posted shows the small jumper wire going to the no.2 terminal on the alternator so you do have the internal regulated alternator. The question is whether it's a one wire or three wire style and are you getting any output from the alternator. Check with a voltmeter between the large post on the alternator with the + lead and the battery ground with the - lead with the red wire connected to the battery. S/B 14.5 volts +or- a few tenths of a volt. If you get no reading then jump another wire from the alternator stud to the no.1 terminal very briefly, just touch the two and recheck for voltage. If you get a good reading then you will have to complete the conversion like the diagram in post 9.
11-30-2011, 10:17 AM | #15 |
If I'm wrong, correct me please, but looking at your pics, it looks like a 3 wire alt. The white plastic plug on the top, should have a white wire on it as well as the smaller red wire.
The smaller red wire goes to the large post, or through the AMP meter, then back to the large post. The small white wire would go through the warning light, then to the key on position of the ignition switch. The heavier (8 or 10 ga) red wire goes from the large post on alt, to battery positive, or the junction block, if you have one. |
11-30-2011, 11:32 AM | #16 | |
Msgt USAF Ret
11-30-2011, 01:13 PM | #17 | |
I would keep it as close to the diagram Vettevet posted in post 9, you can upgrade certain wires but I wouldn't change the charge wire running across the rad support. Something like this.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-30-2011, 06:02 PM | #18 |
I just have an aftermarket guage, no ammeter guage or anything.
I just want whatever I need to 'make it work'. Some/alot of the engine wiring has been hacked up changed since PO and me as well too.
11-30-2011, 09:18 PM | #19 |
Im pretty sure its internally regulated.
Those are just vortec heads on a older block
