Old 11-26-2011, 03:37 PM   #1
Atommik
Atommik's Avatar
51 Chevy 1/2 ton, My S10 swap
I started seriously looking for an AD truck about a year ago. Craigslist was my main source of vehicles to look at, but I did chase down a few other "I know a guy who's got this truck..." kind of leads. In May of 2011 I found this truck on Craigslist.Name:  51-2.jpg
Size:  7.9 KB I got a hold of the owner and went to look at it after the snow melted!!
Atommik is offline   Reply With Quote
Old 11-26-2011, 03:52 PM   #2
Atommik
Atommik's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
It looked pretty decent and the price was right, so in May 2011 it was mine! I work at a body shop and my boss let me (with some help from co-workers) spend a couple of days tearing it down. The plan was to tear it down and basically bring home the body and donate the driveline to a guy who collects and sells parts for pre-47 trucks. He would come and get it, and use what he could from it. My work space at home is very limited. 2 car garage, with my wifes mini van taking up half!!
Old 11-26-2011, 04:03 PM   #3
Atommik
Atommik's Avatar
I'm planning to get an S10 frame in the spring. So in the mean time I'm doing the bodywork on the loose parts. I cut out the rusted cab floor, toe boards, and inner kick panels and replaced them. I had a local sheetmetal shop bend the floor piece for me and I made the toe bpoards and firewall pieces myself. I bought the kick panels on-line. I may need to cut a trans tunnel at a later time...I added some extra bracing to the floor since I cut out most of the seat frame.
Old 11-26-2011, 04:12 PM   #4
Atommik
Atommik's Avatar
With the cab floor mostly done, I am moving on to other parts. My boss lets me bring in parts to work, and work on them over lunch, break time and after work. All four fenders are quite beat up, but not very rusty for a 60 year old truck that spent it's whole life in Minnesota!! I'm finished with both rear fenders, straightened and primed, blocked and reprimed for final sanding before paint. I probably have 30 hours of labor into the rear fenders...2/3 of it metal work!!
Old 11-26-2011, 04:26 PM   #5
Atommik
Atommik's Avatar
The doors are my current project. I started with the pass. door because it has less rust to deal with! I tried soaking the bottom of the doors in phosphoric acid to remove the rust. It worked pretty well! I have more rust to deal with than I thought. I made repair panels for the inner and outer panels on the door. They are all welded in and now I'm fixing a few dents in the door. I sand blasted the jams of the door and now have that in epoxy primer. I'm hoping to finish the right door this coming week and start the drivers side next week.
Old 11-27-2011, 12:46 AM   #6
Root2812
Root2812's Avatar
Nice truck. That looks to be about the same condition as my 50. Minnesota winters take their toll on the floors. My floor looks just like yours did before you fixed it.
Photobucket of my truck --> http://s901.photobucket.com/albums/a.../1950%20Chevy/
Root2812 is offline   Reply With Quote
Old 11-29-2011, 08:29 AM   #7
Atommik
Atommik's Avatar
Yeah, and this truck sat outside for at least the last 5 years with basically no windows except the windsheild! The only other real rusty areas are the cab corners, (front and rear).
Old 11-29-2011, 09:05 AM   #8
xpickup
xpickup's Avatar
Atommik, Looks like a great start. They all seem to have the same rusted areas.
Shannon
xpickup is offline   Reply With Quote
Old 11-29-2011, 08:07 PM   #9
Atommik
Atommik's Avatar
Shannon, I've been watching your builds, nice work!! You inspired me to build my own truck bed, front bed panel and tailgate. Probably won't start them until March or April though.
Atommik
Old 11-29-2011, 08:09 PM   #10
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good, keep the pics coming.
Kabwe is offline   Reply With Quote
Old 11-29-2011, 08:20 PM   #11
Atommik
Atommik's Avatar
Here's a few more mics pics. That's me on the left, and my cramped work space at home (bottom pic).
Old 11-29-2011, 09:17 PM   #12
xpickup
xpickup's Avatar
Atommik, Thank you. Let me know if you need any pictures, dimensions or how I do them. Just take your time and watch your heat and it is not too bad.
Shannon
Old 11-29-2011, 11:39 PM   #13
Atommik
Atommik's Avatar
Thanks, I'll let you know if I need anything.
Old 12-04-2011, 06:19 PM   #14
Atommik
Atommik's Avatar
I finished the body work on the right door, primed it and blocked it. Found one small low spot. Will fix that, then reprime. Hoping to start the other door this week. It needs some serious metal work on the inner lower. I'll see if I can make some repair panels, otherwise I may have to buy a patch panel!
I've been working out the details in my head for LED turn signals, parking lights and brake lights...shouldn't be too difficult.
I will have HID (Xenon) headlamps retro-fit into the original headlamp buckets and trim rings. I'll post pics if anyone is interested!!
Old 12-13-2011, 12:36 AM   #15
oldman3
oldman3's Avatar
You've been doing some good repair work on the fenders, doors, etc. Headlight deal is great. Keep posting up the build....Jim
oldman3 is offline   Reply With Quote
Old 12-17-2011, 02:16 AM   #16
Atommik
Atommik's Avatar
Cleaned up and refinished the vent window frame for the right door. Finished bodywork and priming/ blocking on right door and brought it home for storage. Will be taking the left door into work to start on it this week.
Old 12-18-2011, 12:00 PM   #17
oldman3
oldman3's Avatar
Nice repairs to the door....Jim
Old 12-18-2011, 05:36 PM   #18
Wybrow
You're doing a great job on this. I have a lot of the same body work ahead of me, nice to see what you've done.
Wybrow is offline   Reply With Quote
Old 12-18-2011, 06:41 PM   #19
Atommik
Atommik's Avatar
Thanks Jim, Wybrow...
After getting a good look at the drivers door bottom, and my "success" on the other door, I'm definately going to try to make my own repair panels for the inner door. I should be starting on it this week.
Old 12-27-2011, 08:36 PM   #20
Atommik
Atommik's Avatar
Decided to take advantage of unusally "warm" Minnesota weather (35 degrees) and sand blast the inner fender panels. Was going to wait till spring, but it's supposed to stay "warm" this week, so I can sand blast outside!
Old 12-28-2011, 02:18 AM   #21
Root2812
Root2812's Avatar
I am so glad to hear that. I had to leave my truck in MN while I came down to Louisiana to finish grad school. I'm coming home in a few days and I pray it will stay warm enough for me to get a little bit done before I have to head back south. I was figuring the truck would be under 2 or 3 feet of snow by now.
Old 12-28-2011, 06:51 PM   #22
Atommik
Atommik's Avatar
High's in the 30's all week and no snow in sight!!
Old 01-01-2012, 11:23 AM   #23
Atommik
Atommik's Avatar
I got the inner fenders and braces sand blasted and epoxy primed this week. Now back to the door rust repair!!
Old 01-04-2012, 01:02 PM   #24
99 to Life
99 to Life's Avatar
love the progress. I will be doing the same exact thing on my next truck. Lots of metal work. subscribed
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-04-2012, 01:40 PM   #25
xpickup
xpickup's Avatar
Atommik, nice job on the doors. I can not wait to see the headlamps lite. They say they are great to drive with. Great job.
Shannon
