04-07-2012, 07:50 PM | #1 |
5.3 swap with 4l80 transmission
I am thinking about doing an LS swap into my 71. I found a 5.3 motor with a 4l80E transmission that is in a 3/4 ton 2000 model truck that was wrecked. Is that transmission OK? I've heard that it's better to go with the 4l60 since it's lighter. I don't plan on modifying the engine at all.
Any comments or suggestions are appreciated. Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
04-07-2012, 08:00 PM | #2 |
Still Learning
Re: 5.3 swap with 4l80 transmission
Yes a 4L80E is actually a stronger transmission and you should be fine with that combo.
The extra weight won't hurt you. |
04-07-2012, 08:02 PM | #3 |
What did you use in yours?
04-07-2012, 08:08 PM | #4 |
Still Learning
I have a 4L60E in mine. But if I had the chance to get a 4l80E I would be all over it if the price is right. I only used the 4l60 because it was cheap.
04-07-2012, 08:17 PM | #5 |
I have never seen a 5.3 in a 3/4 ton. I'm not saying it is'nt possible but I'm pretty sure that the 3/4 ton standard motor is the 6.0. I'm not one to say my knowledge is the final say but I do build later model chevy trucks [and GMC's too] for a living and owned quite a few and looked at thousands of them wrecked and I 've never seen a 3/4 5.3. Either way the engine trans combo is awesome and you will be very happy with either one I would say.I have put a 6.0 4l80e in my 68 LeMans convert and a 5.3 4l60E in my 89 C1500 loved them both. Also, depending on who reflashes your PCM for your truck, it will open up some HP and torque just by changing a few maps inside.
04-07-2012, 08:18 PM | #6 | |
04-07-2012, 09:23 PM | #7 |
Still Learning
I would buy that combo for $700 that is a good price.
Posted via Mobile Device |
04-07-2012, 09:29 PM | #8 |
4L80E is stronger, heavier, larger and has more parasitic loss (HP to the rear wheels). I personally think they are noiser too.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
04-07-2012, 09:51 PM | #9 |
My engine came out of a 2000 3/4 ton, 5.3 4l60, has the tag on the cowl to match. I was told the only 5.3's that had the 4l80 were in vans....
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
04-08-2012, 09:28 AM | #10 |
well as I said I have never seen a 5.3 in a 3/4 ton I have also never seen a 4l60e in a 3/4[ in that body style]. The van gvw's are rated a little different and they did have different motors avaible. I have seen 4.3 v-6's with a 4l80e behind it . One of the moving companys had some built[they have yellowtrucks] it will be easy to determine as all it takes is to look at the motor ,the size is stamped on it on the back and the sides. and no pcm or wiring would have to be changed out to work. In fact you can take out a 4.8 and replace it w/5.3 or 6.0 or vice versa. it won't run perfect I would suggest a reflash but it will go.
04-08-2012, 09:33 AM | #11 |
I will step in the kitchen for a knife and fork to eat some crow after my last post where I once again said I've never seen one I went to GM parts express and plugged in a 00 model 3/4 and it does list the 5.3 I was WRONG and I am sorry if anyone was messed up in any way from my misinformation
04-08-2012, 11:10 AM | #12 | |
04-08-2012, 01:52 PM | #13 | |
bbadfred
04-08-2012, 03:01 PM | #14 |
Still Learning
I could retire if I had $10 for every time I was wrong
04-08-2012, 06:49 PM | #15 | |
The 5.3/4L80E combo is a whole other can of worms...... 99 & 00 LQ4 6.0L are different than 01 & up 6.0L's, The rear crank flange is longer than any other gen III engine, Also the only one to have iron heads. The longer crank flange was designed for use with the 4L80E transmissions converter spacing. 01 & up LQ4 6.0L's use a spacer to deal with the converter spacing, Because the LQ9 came out with a 4L60E/4L65E So does a 99/00 2500 LM7 5.3L have a MT1 4L80E behind it.....I dont think so. It would have 4L60E..........Untill someone can show RPOs LM7 & MT1 on the same RPO sheet.....There is no proof. Last edited by clinebarger; 04-08-2012 at 06:55 PM. |
04-08-2012, 08:10 PM | #16 |
I'm going to go look at it tomorrow, so we'll see if I can figure out what's what.
04-08-2012, 12:38 PM | #17 |
Ive had a plate of that more than once in my life
04-08-2012, 08:28 PM | #18 |
The passenger side of my trans has 4l60 raised on it, should be easy to spot.
04-08-2012, 09:43 PM | #19 |
I have a 5.3/4l80e combo in my blazer. It isn't the best combination for power or fuel mileage but if you ever decide to add some boost it is one of the best combinations to have.
04-23-2012, 12:35 PM | #20 | |
Agreed, I too have a 5.3/4L80e combo (bought seperately). Although I get 18-19 hwy and 12-14 city.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
