04-13-2012, 04:29 PM | #1 |
Re-installing cab divider trim?
The PO of my truck shaved all of the upper and lower mouldings and not only removed the cab divider trim, but removed the moulding nubs. I was wondering if there was a way to re-install the cab divider trim using moulding clips and sheet metal screws. Is there another way of doing this?
Thanx in advance Dano
'69 Fleet It ain't yours, if you didn't build it! |
04-13-2012, 05:24 PM | #2 |
Re: Re-installing cab divider trim?
Dan, All the after market vendors sell a set of screws made just for this. I got mine from Mar-K along with the trim. Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-13-2012, 08:06 PM | #3 |
Thanx man!
04-14-2012, 01:15 AM | #4 |
GM still sells the screws, got mine at the local chevy dealer, took 2 days to come in, part#4492963.
04-24-2012, 01:32 PM | #5 |
Or you can make your own psuedo clips and use 3M double sided molding tape to attach the molding. That way you don't have to drill on your cab and possibly cause rust issues later.
04-24-2012, 09:09 PM | #6 |
The stud gun kit I use has a tip for putting those pins back onto sheetmetal. It will only work if your still in the prepaint stages
04-25-2012, 06:08 AM | #7 |
X2 on that. I've not installed mine yet but should be easy enough with the new screws. After you drill just touch up the hole so you won't have exposed metal ready to rust.
04-25-2012, 10:24 AM | #8 |
i took all of the moulding off of my truck but this is the only trim i like on these trucks. i just wonder how it would look with this being the only trim on it.
if i was a little more fab friendly making the back window 2 or 3 inches bigger.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
