Old 05-12-2003, 05:48 PM   #1
project1971
project1971's Avatar
Question What steering gear can i use???
alright guys you were extremly helpful on the coloum so what steering gear can I use to convert to power steering? Will a gear off a 80's IROC?? with quicker steering ratio? Thanks for your help!
project1971 is offline   Reply With Quote
Old 05-12-2003, 11:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think you are limited to getting one off a truck...but I may be wrong.
Old 05-13-2003, 03:36 AM   #3
73stepside
73stepside's Avatar
the car steering gears are completely different and can't be used. i was told by a guy at classic chevy that any one will from a 73-79. 80-87 went to metric. they may interchange to but you will need the whole set up and then change the brackets to short water pump style.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-13-2003, 04:08 AM   #4
ZOOMY
ratio
The ratio on the truck power steering boxes is quicker than the manual boxes in case you didn't know...........Zoomy
ZOOMY is offline   Reply With Quote
Old 05-13-2003, 06:21 AM   #5
short step
i just used i from an 87 you have to move the alt to the other side need long w/pump and all the brackets&pullies&pump they went from flare to o rings works great
short step is offline   Reply With Quote
Old 05-13-2003, 08:48 AM   #6
andyr354
I got one from a 76. You can use the newer one by having your own hoses made as well.
Went that route on a 4x4 one time, just crimped the right end on the hose at the parts store. Much easier than changing everything else.
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust.
andyr354 is offline   Reply With Quote
Old 05-13-2003, 12:15 PM   #7
project1971
Thanks again for all your help all you guys have been great.
I am going to get one off a mid 80's and It's getting all the late model brackets and serpentine belt. Also going with TBI with aft axle tank. will post some pic when i get them and keep you all posted.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
Old 05-13-2003, 09:20 PM   #8
Longhorn Man
if you are going to the serpentine set up, either grab the water pump or get a new one for a newer truck.
They are all reverse flow pumps when they came with a serpentine belt set up.
