07-03-2012, 10:35 PM | #1 |
overdrive trans
so in my 1ton with a 454 i want overdrive so 700 R4 , gearvendor, modified Volvo OD unit or ?? please help
thanks as always Henry. |
07-03-2012, 10:40 PM | #2 |
Re: overdrive trans
I wouldnt use a 700R4 I have broken a few of those.. i say the best setup up for a big block is a th400 with a gear vendor unit
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
07-04-2012, 09:42 AM | #3 |
Re: overdrive trans
I don't know much about non GM transmission but I do know about the 700. The 700 R4 can be built solid to handle that 454. 1rst gear in a 700 is lower than both the 350 and 400. Make sure that you find a 30 spline not the 28 spline 700 used in most 6 cyl. models. Look for a late 80's early 90's. If you have a Dayco transmission parts shop near buy get the ceramic disk upgrade with master overhaul kit and have a recommended bench tech install it. You will also need to buy the 4th gear electric lock up conversion getI think summit has it? The stock disk packs in the 700 and a lot of other stock transmissions use a minimal amount of disks for each gear+ the stock disks are coated with a paper/cork material- This is what fails in these transmissions and this is why the 700 gets a bad wrap. When you upgrade to the ceramic disks you get a better grip - and more disks working together for each gear.. You can build a stock 700R4 to handle 1000+ HP.
That's a monster truck what will you be towing? |
07-04-2012, 09:56 AM | #4 |
Re: overdrive trans
I think by the time that you spend the money to get a 700 to survive behind a big block in a 1 ton, you could have easily had a used (or possibly rebuilt) 4l80e with the stand alone controller. Now if you're using the truck like a 1/2 ton, that may be a diffferent story. I use my 1/2 ton like a 1 ton and I'm looking 4l80 or nv4500 (manual).
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-04-2012, 09:50 AM | #5 | |
It's Better With Nitro
Re: overdrive trans
It will probably be more economical to find a 4L80E. This is the route I generally go. Remember, before the Allison 1000, the big block trucks came with the 4L80Es.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
07-04-2012, 10:33 AM | #6 |
Re: overdrive trans
07-04-2012, 12:05 PM | #7 |
Re: overdrive trans
I can usually find used 4L80Es for around $500-$800. I use the Baumann Optishift TCU for around $500. I've never been able to make a 700R4 live behind my Pontiacs, and my racing transmission builder, Mike Stewart of Mike's Transmission - http://mikestransmission.com/, will not build one for my hot rods because they will not last with the torque I make...but, he has built me TH400s that handle my 1500+ ft-lb blown Pontiacs. The 4L80E is basically a TH400 with OD...keep in mind, it's not the horsepower that kills the trans, it'll be the torque.
