07-13-2012, 03:00 AM | #1 |
error 404
88 350 will start won't run
Engine will not idle, to keep it running i will lightly push the gas and it will fluctuate up and down, almost dying when it drops down. when given full throttle it will starve for fuel and die. heres the list of new parts ive put in.
coolant temp sensor fuel injectors fuel filter cap rotor wires plugs fuel pressure regulator TPS I have to believe this is a low fuel pressure issue, could my pump be weak? I didn't think an electric fuel pump could go "bad" I thought it either works or it don't. any help much appreciated.
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD 90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace. 06 Kia sorento wife's car 06 charger srt8 "lucifer" my toy '12 Kia optima |
07-13-2012, 08:24 AM | #2 |
Re: 88 350 will start won't run
Your problem sounds just like when my fuel pump died.
07-13-2012, 09:12 AM | #3 | |
It sounds like low fuel pressure to me. As these truck get old, the hose in the tank between the pump and the sending unit is becoming a common failure point too. The pressure should be tested with the engine running. There is a link to testing information in the FAQs sticky at the top of the board.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
07-18-2012, 01:38 AM | #4 |
error 404
Yep, it was a fuel pump, thanks guys!
