Photo needed of Hood Latch 1972 Blazer
My hood stopped popping up when I press the hood latch.
Thinking a spring belongs somewhere and I would like to compare a working latch to mine I need a photo of the hood latch on the radiator support and on the hood side for a 1972 Blazer. Thanks in advance Tbruz |
![]() Join Date: Jan 2001
Re: Photo needed of Hood Latch 1972 Blazer
I didn't see this until after it got dark (I was working on the 79 Camaro with my son) but if there's not a reply by tomorrow morning I'll take a picture and post it. Is it the view from the top you need?
Thanks, Need one pic; hood side(latch pin side) showing the pin that fits into the latch on radiator support; need to see if there is a spring there or not.
A second pic looking into the latch mechanism on the radiator support would be appreciated as well. Thanks again. Does your hood "pop" up a bit when you first unlatch it or do you have to gently pry it up with your finger tips to get under the leading edge? Tony |
Tbruz, I have to do just as you described with mine, pull the latch and then stick my fingers under the leading edge and pry it up. It doesn't jump up like every other car I have here.
No spring on mine anywhere that I can see, but I sure wish it had one. I never really thought to look into it but I'd have to believe there should be one. |
I think this is what you're looking for. If not, let me know, and I'll try to get it for you.
Yep, just looked at mine. It's identical to that, no spring anywhere.
Thanks Truckster those are the exact shots I was hoping for.
Does seem like there should have been a spring on the hood side to help with the "initial lift" ,if you will, of the hood. Seeing these photos I no longer think anything is missing, just maybe got misaligned somehow. Thanks again Tbruz |
You guys got me thinking about mine. Seems like mine pop up, I have four of them Ill check tomorrow.
Posted via Mobile Device |
Thanks Brian, I've always wondered about it myself but never thought to ask.
I'm glad Tbruz brought it up. If there ever was a spring on these things there might be a good chance of finding one if you have 4 to look at ![]() |
Maybe check the distance from the 4 bolt flange to back side of cone, mine was 1-1/8" also check hood bumpers are adjusted. Mine pops up rather hard (with no spring) to the safety catch
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
![]() Join Date: Oct 2006
I think the spring should actually sit on the bottom support attached to the grill. If you look at the photo, there are 4 holes around the edge of the hole. One is for the bent end of the spring to sit in and the one opposite of it is for a small screw/washer combo to hold the spring down.
#12 | |
I've tried adjusting the rubber bumpers, any higher and the hood won't shut correctly and line up with the tops of the fenders. |
I am pretty sure it is all in the hood hinges and spring
member #16
![]() Join Date: Dec 1999
Adjust your hood bumpers up a bit tighter, and see if that does it. Mine pops up fine with no spring. Never seen a spring on a stock truck latch. If that doesn't work adjust the latch stud up so it loads it up somewhat.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#15 | |
I'm pretty much all out of adjustment ideas on mine. The rubber stoppers are up to the point where any higher and the hood will sit higher than the fenders. I've adjusted the latch stud to a point that you literally have to slam the hood to get it to latch, sometimes it even takes me 2-3 tries, and I still have to pry that thing open with my fingers. I really don't like slamming that thing so I'm probably going back to an easier setting. It definately needs a spring. |
#16 |
I'm pretty sure that there were no springs on these models, I believe Dantes Jimmy and John are correct about the hinges, springs, and latch stud. Maybe springs are weak or worn rivits in hinge.
#17 |
![]() Join Date: May 2011
tbruz,get a hold of Frank _ Pickmup_ hes got just what you need. ineed one too, but gonna wait till another part is done to order.
#18 |
X2, remember seeing it in the classifieds. Looked like it would solve the problem
#19 |
I haven't tried it, but 2nd gen Camaros have a similar latch pin and there is a spring that is integral to them. It may need a small amount of modifying, but might be worth a try if you happen to have one setting around.
Website for images of Camaro latch assy. http://www.apiem.com/camaro/BumpersGrille20091222.asp |
#20 |
they never did come with a spring.
#21 |
In my spare time I'll a adapt a spring from my spare parts cars and make it look stock. Won't take much time. I'll make a post when it's done.
#22 |
I just checked my various blazers and they pop up when you initially unlatch the hood. Some better than others but my 1969 works the best, it allows me to het my hand under the hood to lift it, no prying it up.
#23 |
brianK ,
Do your trucks latches look like the pics in post #5 or is there something different. Thanks Tbruz |
#24 |
Old member
Depending on how well you have the outer snubber's adjusted and the bullet adjust will make the hood pop up correctly. The hood hinge springs will detirm how much it pop's up.
The two outer snubbers on the corners of the hood and the bullet have to be correct for it to lift though! The trucks are the same way. ![]() ![]() Black snubber lower right corner in picture.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#25 |
Yep, they're all the same.
