02-28-2013, 10:00 PM | #1 |
Box Removal
Can someone tell me how to get the box bolts out with the nuts spinning? This is on my 2001 long box. What a crappy design. I assume GM welded the nuts in and now the welds have let go. I could just cut the bolts but then I couldn't reuse the nuts as they would be filled and still spining
03-01-2013, 09:38 AM | #2 |
Re: Box Removal
might have to use a hole saw and cut a hole in the floor above the nut and use a socket to hold them
03-01-2013, 01:33 PM | #3 |
Re: Box Removal
How many are spinning? If its only one or two just cut the heads off and leave those holes empty. There should be like 8 bolts holding it to the frame.
Posted via Mobile Device |
03-02-2013, 02:14 AM | #4 |
Re: Box Removal
;You need to cut a window in the side of the u channel by the bolt to get ahold on the nut,you can install a j clip nut on though the hole to install the box
