Old 04-13-2014, 12:40 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Project: 1972 K30 Crew Cab Duramax
Been collecting parts for this one since project penicillin was unveiled years ago and finally putting some work in on it. I have seen a couple of new builds that had different ideas that I have seen and am copying but this the plan.
1972 K30 Cheyenne Super 4x4 crew cab short bed
*1971 Suburban 4x4 freebie (thanks Leon)
*1971 c30 157" wb cab & chassis frame
*1989 v3500 axles (freebie)
*03 lb7 duramax 6.6L, Allison 5spd, and dodge cummins np205 29 spline (89-93)
Though I already have freebie drive train parts from the v3500. TBI 454,rebuilt th400, and np205
*Factory dual Cheyenne inner roof panels
*factory buckets & console
*c30 roof with cab clearance lights
*factory dual shoulder harness setup
*AM/FM
*8 track player
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-13-2014, 12:50 PM   #2
71blksuper4x4
SWB 4x4 Collector
Re: Project: Big Grapefruit
Getting started:
TREVOR
Old 04-13-2014, 12:54 PM   #3
71blksuper4x4
SWB 4x4 Collector
Progress: lots of cutting
TREVOR
Old 04-13-2014, 01:01 PM   #4
71blksuper4x4
SWB 4x4 Collector
Progress: getting the back of truck cab roughed in
TREVOR
Old 04-13-2014, 01:03 PM   #5
71blksuper4x4
SWB 4x4 Collector
Floor board fix
TREVOR
Old 04-13-2014, 01:07 PM   #6
71blksuper4x4
SWB 4x4 Collector
Starting on 4th door pillar:
TREVOR
Old 04-13-2014, 03:24 PM   #7
ryanroo
ryanroo's Avatar
looks like a sweet start!
I would say if you go with the BBC, you may want to look into an OD trans. TH400 is a beefy unit, but it wont be the most drivable. but given my current project(predicament) i vote 12v!
i do love the TBI 454 in my Jeep. it is hooked to a nv4500 and is pretty easy to drive and fun as well.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-14-2014, 09:06 PM   #8
sdailey
The Few, The Proud
sdailey's Avatar
Along for the ride Trevor.
Don't see any tow hook mounting holes in the frame. Gotta have those.
Shannon
sdailey is offline   Reply With Quote
Old 04-14-2014, 09:49 PM   #9
71blksuper4x4
SWB 4x4 Collector
Thanks guys....I have been wanting to work on one of my projects for awhile. You know how that goes though, you get asked favors for friends a lot. I feed off of the encouragement and support though. Trevor
TREVOR
Old 04-14-2014, 09:52 PM   #10
71blksuper4x4
SWB 4x4 Collector
Tonights progress: big step in the pillar project.
TREVOR
Old 04-14-2014, 09:58 PM   #11
71blksuper4x4
SWB 4x4 Collector
Oh and Shannon, one frame rail had the holes, the other didn't?????
TREVOR
Old 04-14-2014, 10:48 PM   #12
bilfman
bilfman's Avatar
Looking forward to see more I am a sucker for crews!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-15-2014, 12:41 AM   #13
rgreathouse
I'll be watching! Looks good so far... Go with a 12v/nv4500/205!!!
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 04-15-2014, 07:20 AM   #14
ryanroo
ryanroo's Avatar
is this going to be a dually? or do you plan to convert that 60 to SRW? was it a C&C truck or did it have a bed?
72 K20 12v build
Old 04-15-2014, 11:47 AM   #15
swamp rat
swamp rat's Avatar
Subecribed!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-15-2014, 12:48 PM   #16
CUSTOM/10
CUSTOM/10's Avatar
You have some good metal fabricating skills Trevor !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-15-2014, 08:29 PM   #17
71blksuper4x4
SWB 4x4 Collector
Thanks guys!
Ryan, I plan to make this a srw crew short bed, I still need to gather the hubs for the swap. The 89' was a C&C wrecker that I got for working a trade on putting the wrecker bed on a v10 Dodge and hand painting his business along all of it.
And no, not a great metal fabricator but have a desire and drive to always get better.
TREVOR
Old 04-15-2014, 10:37 PM   #18
71blksuper4x4
SWB 4x4 Collector
Progress: 4/15/14
Managed to get a couple hours after work to tackle some more on the pillar. Everything is measuring accurate to the passenger.
TREVOR
Old 04-20-2014, 11:13 PM   #19
71blksuper4x4
SWB 4x4 Collector
I think I may change my frame plans and rob the 4x4 pieces off mine now to this one.
TREVOR
Old 06-09-2014, 10:43 PM   #20
71blksuper4x4
SWB 4x4 Collector
Progress: almost to the easier part..a lot of fine details on the pillar, bear with me.
TREVOR
Old 10-14-2014, 11:27 PM   #21
thebowtieranch
Looks great I will defenitly be following your thread and try to do send catching up to you.
thebowtieranch is offline   Reply With Quote
Old 09-21-2016, 06:13 PM   #22
70custom20
70custom20's Avatar
Re: Project: 1972 K30 Crew Cab Duramax
Holy s*** is that a lot of work, it looks great. I would love to do something like what you're doing, I'd probably be in my 50's (I'm 43 now) by the time I got done with it, IF I got done with it. Great work, this is a truck that GM should have built.
70custom20 is offline   Reply With Quote
Old 09-21-2016, 06:19 PM   #23
70custom20
70custom20's Avatar
I know it's been a while since this thread had any traffic, or updates. Holy **** is that a lot of work, it looks great. I would love to do something like what you're doing, I'd probably be in my 50's (I'm 43 now) by the time I got done with it, IF I got done with it. Great work, this is a truck that GM should have built.
Old 04-15-2014, 12:46 PM   #24
willett
Another Day, Another Dollar
willett's Avatar
Dang you make it look easy
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-15-2014, 10:00 PM   #25
ryanroo
ryanroo's Avatar
Sounds good. that rear housing makes it pretty easy to get back to a normal width. i wish i had a spare set of SRW outers laying around. i wouldnt mind making that trade. i sold the spare set i had a while ago. i have always toyed with the idea of making the yellow truck a dually...
i admire your work so far. i want to build a crew, but i dont think i could manage to do extra door and the roof pancake. i dont trust my sheet metal fab skillz. i am looking forward to seeing how you takle the chassis and 12v swap
72 K20 12v build
