Old 01-12-2015, 01:57 AM   #1
suburban99
suburban99's Avatar
1962 LS swap engine position
Swapping a 5.3 and 4l60e into a 1962 c10. Using dirty dingo adapter plates (3 position) with chevy clamshell mounts on a 1978 disc brake K-member.(finally figured out the mounts)
Using 2010 6.2 Camaro exhaust manifolds as frame on the 62's are quite narrow. Thought about positioning engine to line up the transmission support and calling it done...
Any suggestions? Thanks
suburban99 is offline   Reply With Quote
Old 01-15-2015, 10:16 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: 1962 LS swap engine position
Set her in, where it all fits....build from there? Don't view this a s a smart azz answer, you need to "fit" all the parts, on this swap (center engine/trans), bubble the 2 pcs , my thoughts are 3 - no more that 4 degrees down, on the eng /trans @ ride height, with all the weight on the truck. Where she fits for you, may be different, than my swap? best of fun,longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-15-2015, 11:40 PM   #3
yossarian19
Far back & low as you can. Make sure you have space for electric / mechanical fans (whichever you are using)
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 01-31-2015, 03:17 AM   #4
suburban99
suburban99's Avatar
Well got the engine in the frame. It's a tight fit on a 62 frame...used 2010 Camaro Manifolds..transmission mount is in stock location. I have about 1/4" clearance between frame rails and manifolds.
Old 02-01-2015, 06:02 PM   #5
amueller454
amueller454's Avatar
looks good. im swapping a 5.3 into my 61 as well. do you think 2010+ camaro longtube headers would fit in these frames?
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 02-01-2015, 06:23 PM   #6
suburban99
suburban99's Avatar
I really don't know. Most swaps I have seen are done with the Camaro manifolds. The feedback that I have got from various sources say that is the easiest way to go. The frame is very tight where the manifolds dump...hopefully my cab will go back on smoothly with the engine in this position. The frame on this truck is mint as it was from California..I really didn't realize the earlier ones were that much different from the 64-66.
Old 02-01-2015, 06:34 PM   #7
amueller454
ok thank you. did you buy an adapter bracket to mount your power steering box? or what did you do
Old 02-01-2015, 06:38 PM   #8
suburban99
suburban99's Avatar
Truck came with a '78 disc brake front end. Steering box was already attached. Doesn't look like an adapter was used. I can send a pic if you want.
