how to remove vaccum line for hydroboost
I feel dumb asking but is there a trick to pulling of the vaccum line that goes to the brake booster, Im going with hydroboost out of an Astro van, and also how do you plug it? My engine is a 2002 5.3
![]() Join Date: Feb 2004
Re: how to remove vaccum line for hydroboost
If I remember right there is a little red tab you press in and pull plug, gm offers a barb that snaps in for 7 bucks. Maybe some one will chime in with the pt # it's been long since I did mine
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
![]() Join Date: Sep 2005
Ive been searching for that part number for like a year now
Thank you Fellas.
![]() Join Date: Sep 2014
I bought a rubber cap from Amazon and pulled the line off of the back of the intake and the rubber cap fit good and tight over the barbed piece. Here is what I bought- Amazon.com: Dorman 02253 Bypass Cap Assortment - Pack of 8: Automotive
This is what I found.
"If I remember right there is a little red tab you press in and pull plug, gm offers a barb that snaps in for 7 bucks. Maybe some one will chime in with the pt # it's been long since I did mine"
Any one know the part number for the barb fitting for the intake manifold for vacuum brake booster? I have been searching with no luck. I picked up an engine out of an express van that had hydroboost, but I want to stick with standard brake booster. Thanks for the help.
1972 Cheyenne C10 LWB 1970 C10 292 I6 3 speed 2017 Silverado LS 4x4 1978 El Camino SS, LT1 swap 2016 Camaro SS |
http://67-72chevytrucks.com/vboard/s...d.php?t=503167 you will find it here
So you don't have to go looking #12559760. That is what I also removed off my 6.0 when I did my Lemans convert but I used it on my 89 C1500 diesel changeover. Jim
