1961 crewcab
dropped spindle steering question
I am using a 73-87 front end, I was able to trade for a set of 3" dropped spindles, however they have been drilled out for a 5/8 bolt to be used with a late model rack and pinion.
I found this product in the speedway race catalog- http://www.speedwaymotors.com/IMCA-A...4&pr_feat=ANNO which looked like it would do the trick, but upon asking them they did not think that their inner tie rod end would work on the truck. I could try piecing something together like that, they do sell single heim joints and different lengths of sleeves... do any of you know the thread count and size of the stock 73-87 inner tie rod end? any other ideas/solutions besides a rack?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
Re: dropped spindle steering question
been trying to do some internet research.....
should I try this instead? http://www.autozone.com/suspension-s...on/855296_0_0/ -it is for a fox body mustang... ... or maybe just order some new dropped spindles (about $210), and save these drilled out ones (for a dropmember), or sell them? I found this thread on how to relocate the 86 steering after the pancake, and it takes a pretty big notch out of the frame... http://67-72chevytrucks.com/vboard/s...d.php?t=649493 ..so maybe it would be better to go with a rack?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 04-21-2015 at 11:10 PM. |
