Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-23-2015, 05:29 PM   #1
65chevysub
65chevysub's Avatar
lights flicker upon startups- '04 Blazer
I just noticed on our 04 S10 Blazer that the clearance lights flicker for a bit right after starting then it stops. We had the alternator replaced a couple months ago.
Any ideas and should I be concerned and have the electrical system tested?
65chevysub is offline   Reply With Quote
Old 08-25-2015, 08:05 PM   #2
65chevysub
65chevysub's Avatar
Re: lights flicker upon startup
Update on my post. All the lights pulsate for a little while after starting(about5 minutes) then it stops. Could this be a ground issue?
Old 08-25-2015, 09:08 PM   #3
cdowns
cdowns's Avatar
Could b a bad ground or just dirty filthey contacts that have not been cleaned and tightened up for years
Old 08-25-2015, 09:32 PM   #4
65chevysub
65chevysub's Avatar
Should I start with the neg cable then check all the lights? All the dash lights and exterior lights are pulsating
Old 10-29-2015, 11:39 AM   #5
65chevysub
65chevysub's Avatar
Maybe someone can give me some advice. Our 04 Blazer LS developed a draining issue. It's been working fine except the flickering lights. The battery seems to be draining overnight, but there is nothing left on. I cleaned the inside on Monday and accidentally rotated the done light switch on. I figured that out and made sure it is off now. When I get in to start it in the morning, it turns over real slow several times then it starts. The rest of the day it starts fine. Im going crazy trying to figure this out. I cleaned the battery cables and they are tight.
Can someone give some ideas? Im having to wait til funding allows to get it to the Auto electric shop.
Thanks in advance for help and sorry for this looong post
Old 10-30-2015, 08:32 PM   #6
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Sorry to hear you're having electrical problems!
To get this thread Rollin ' to a fix, I'm m moving it over to the electrical forum.
Good luck,
Ellen
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 10-30-2015, 10:00 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: lights flicker upon startups- '04 Blazer
This most often points to a voltage regulator issue. Of course it's in the alternator, before you buy a new alternator try checking all the connections to the alternator including the plug and the wire(s) in it.
With a fully charged battery I would disconnect the alternator wiring and start the car to see if the flickering happens. This would isolate the alternator from the system as a cause.
You most likely will see some codes relating to no charging but they can be reset.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-01-2015, 01:27 AM   #8
65chevysub
65chevysub's Avatar
Thanks for the reply, however the alternator was replaced in February. I'm going to have the battery check tomorrow to see if its going bad. I will post on here what I find out.
Old 11-02-2015, 06:07 PM   #9
65chevysub
65chevysub's Avatar
Update: had battery checked and it's bad. Going to get a new one on Thursday then wilk check the flickering light issue.
