Hello all! Got a question for ya. So, I have in my possession an SA-8 V1.5, a 375-watt RMS amp, a capacitor (if I need it), and I just ordered some 4-gauge welding cable.
My question is, have any of you ever put an SA-8 or something similar behind the seat of your truck? If so, how did you mount it, and how does it sound? Links or pictures to your box build? Thanks!
'71 Custom-10 ![]() Rat rod build: 1949 Crosley Station Wagon body on 1993 Dodge D350 chassis, Cadillac 500 powerplant. |
Re: Anyone ever stuck an SA-8 behind the seat of a 67-72?
i'd start by measuring the room available, it should fit
i googled the sub but found no depth measurement truk runs a single 10'' arc audio sub behind the pass seat (along with the battery) and 2 arc audio amps; 400x1 and 600x4 behind the drivers seat space for the sub is behind the sub and arm rest ![]() ![]() sub enclosure follows the stick profile ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
If you are running a bench, the seat is going to need to be way up. Those are a BIG 8" sub and need a significant amount of space behind them. If you DO get it into the cab, it'll be all you need for a standard cab though.
http://www.stevemeadedesigns.com/boa...8-do-you-have/ |
Tags |
sub box, subwoofer, sundown |
