07-22-2015, 06:51 PM | #1 |
Information needed on LED side marker lights
know I saw a post on this before but I will be darn if I can find it...
I got a set of LED side marker lights for my 71... The standard side marker lights are a 2 wire set up and the LED's are a 3 wire... I know my Front lamps work with the turn signals... How do I wire these to work correctly... Thanks... Dan
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
07-22-2015, 07:23 PM | #2 |
Msgt USAF Ret
Re: Information needed on LED side marker lights
Maybe this was it. http://67-72chevytrucks.com/vboard/s....php?p=2122953 Here is the wiring diagram for the marker lights. On the early trucks they didn't blink. I think that the73 or 75 and up models they blinked. Remember the polarity on LEDs is critical, if it's reversed the lights won't work. it appears to be small so I'll see if I can find a larger one.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-22-2015, 09:04 PM | #3 |
Old member
71 and 72 front side markers blink with turn signals on backs don't. My 71 is all LED's and the side markers are just like the orignals.
I bought these and put the good LED bulbs in them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-23-2015, 06:47 AM | #4 |
These are all contained in one unit...
07-23-2015, 10:18 AM | #5 |
all '71-'72 the sidemarkers blink with the turn signal?? how are they wired to do that then? my '72 does not but would like em to
07-23-2015, 11:40 AM | #6 |
Old member
Here is mine. Front side markers have 2 wires and I assume one is parking lights since they come on with the parking lights and the other is the turn signal since they blink. I have never taken them apart to trace but it make since they are tied to the front parking lights wiring.
The rear are only one wire in and out to ground you can see in my pictures. I have never changed the wiring on this truck it's as it came from Chevy. All these video's where taken inside the garage in darkness!
09-07-2020, 08:45 PM | #7 | |
Added a pic of the wiring I found in a manual. As you can see marker does not go direct to ground as shown in the previous diagram. One side to running lamp and the other to turn signal. This could probably be done at the rear tail lamps and marker if desired.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 09-08-2020 at 01:20 AM. |
07-23-2015, 11:48 AM | #8 |
Thank to all for the two wire information but this thread is about hooking up the 3 wire LED lights to the two wire system...
07-23-2015, 04:14 PM | #9 | |
Old member
My reason for the pictures and the info I thought would be helpful to you and 72kool. The factory never ran 3 wires to the front are back. You bought a light that has three wires but your truck only has 2. You will have to figure out which wires are which in your light setup. 1 wire will hook to the parking light wire of the truck, 1 wire will hook to turn signals of the truck the thrid wire will be ground for the LED's it self! LED's need a good ground to operate. You will have to tie the rear light into the wire that is already there for the marker light. Which you will have to figure out which wire to tie to on the light. Then run new wires to each back marker to tie into the turn signals if you want them to flash. Then ground the lights them selves as my pictures show once you figure out which wires on the lights are for the grounds. All my info is just common without knowing the lights that you bought and not being able to check them.
07-23-2015, 05:07 PM | #10 |
thanks for the info andy. where did you get the led bulbs for the side markers? i would like to do all led lights on my truck eventually
07-23-2015, 05:13 PM | #11 |
Old member
The bulbs I got at O Reilly's. Off the shelf.
07-23-2015, 05:30 PM | #12 |
Thanks Andy... your help is greatly appreciated.
07-23-2015, 08:54 PM | #13 |
Here's how I hooked mine up, front and rear side markers blink.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
07-23-2015, 09:00 PM | #14 |
And back
07-23-2015, 09:05 PM | #15 |
Old member
Where did you tie into the turn signal wire? I assume you have them flashing when turning. Can you show a video of how it looks when turning?
I had to get the flasher's when I put the front parking lights in. Before that everything worked without them.
04-09-2018, 06:08 PM | #16 |
I have same set up, My rear side markers also flash with signal and work with parking lights, Problem is they also have braking signal. I connected the red wires together. Should rear be red led side marker to black led tail light?
Last edited by val durio; 04-09-2018 at 06:24 PM. Reason: new post explained question |
07-23-2015, 09:02 PM | #17 |
Also have to have the LED flashers incase you didn't know .
07-23-2015, 09:04 PM | #18 |
07-23-2015, 09:21 PM | #19 |
Spliced into the green wire. So I have one to brown and one to green and the ground. PM me with email and I'll send video, not sure how to upload.
07-23-2015, 09:33 PM | #20 |
Old member
I upload mine to You Tube then paste them here.
07-23-2015, 09:40 PM | #21 |
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) Last edited by 9teen69; 07-23-2015 at 09:54 PM. |
07-24-2015, 09:55 AM | #22 | |
Old member
Elliot949, I got mine when I ordered the lens, but yes I have seen them at O-Reilly's.
07-23-2015, 10:01 PM | #23 |
Hey 9teen69... Thanks a ton... That is EXACTLY what I needed... So did you get your Flasher from like O'Reilly's or someplace like that?...
07-23-2015, 10:23 PM | #24 |
Got mine from Classic Industries but I have seen the flashers at the local auto parts store
07-23-2015, 10:31 PM | #25 |
Thanks...
