Old 09-19-2015, 11:42 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
Is a radiator swap worth it?
I recently put on a serpentine belt system off a 92 chevy truck and am thinking about changing out the radiator to an aluminum one with electric fans. I need to replace the core support due to rust from under the battery box and I was thinking about changing the radiator out at the same time. I found a 3 row aluminum radiator with 2 12 in electric fans on eBay for $150. Didn't sound too high. I think it would look cleaner without the fan and shroud in there, but don't know if it would be worth the money. Any thoughts? Thanks guys.
Kaptain Kadian is offline   Reply With Quote
Old 09-20-2015, 12:48 AM   #2
elkniks
elkniks's Avatar
Re: Is a radiator swap worth it?
That sounds too cheap too me. I'd be weary of the quality. I just installed an Engineered Cooling Products radiator from ebay, still a cheap most likely imported radiator and it seems to be holding up. I also copied someone else's thread here and installed a Jeep Cherokee fan inside a stock shroud. I like it a lot. Moves plenty of air and looks super clean, the fan is inside the round part of the shroud so you cant really see it. I also live a cooler climate so I am not sure how this set up works in high temperature areas.
elkniks is offline   Reply With Quote
Old 09-20-2015, 08:44 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Is a radiator swap worth it?
I'm putting this one in now.
http://67-72chevytrucks.com/vboard/s...d.php?t=681849
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-20-2015, 09:58 AM   #4
Kaptain Kadian
The price does make me kind of hesitant, especially since it is $800 cheaper than some of the other radiators and includes the fans. Might be worth rolling the dice, if it is crap, I still have the old one I could put back in.
