Old 11-18-2015, 09:05 PM   #1
72MARIO
72MARIO's Avatar
Service stability after Steering shaft replacement HELP
Well after replacing the lower steering shaft on our 2005 Tahoe I jumped in excited to have a like new steering feeling only to get a service stability message. Seams like its something directly related to the shaft replacement What did I do wrong ????
Just for reference the lower shaft part number 25958109 dealer price $456.50 CDN got off amazon.ca for $238.80 or its $153 US I cant get over the price difference !!!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-19-2015, 12:12 AM   #2
Blown06
Blown06's Avatar
Re: Service stability after Steering shaft replacement HELP
It is very likely that you damaged the steering wheel position sensor when doing the steering shaft repair. If the wheel spins freely while you have the shaft disconnected the sensor gets messed up. I haven't had it happen to me personally but read tons of horror stories about it prior to working on my 2006 Silverado steering shaft. I actually put a ratchet strap through my steering wheel to keep it in position while I disconnected the shaft. Do some Google searches about the sensor, if I remember correctly it's beneath the steering wheel which means pulling the air bag and wheel.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 11-19-2015, 10:32 AM   #3
72MARIO
72MARIO's Avatar
I tied the wheel to the shifter but it was not fixed still had some movement. But it was not able to spin in circles just wiggle
2005 TAHOE DD
Old 11-19-2015, 07:00 PM   #4
Blown06
Blown06's Avatar
Then that may not be your problem, it was a thought.
Me: Jarrod
Old 12-02-2015, 12:18 PM   #5
beamn7
There are two possible causes for this issue.
•An internal fault within the yaw rate sensor/lateral accelerometer, P/N 15189628, may be the first possible cause.
•The vehicle stability enhancement system (VSES) electronic brake traction control module (EBCM) calibration may be the second possible cause. There is an updated calibration available for this.
Inspect the yaw rate sensor/lateral accelerometer part number located on the sensor bracket which is located under the pass seat. You need to remove the seat to do this.
◦OLD yaw rate sensors/lateral accelerometers have a part number of P/N 15189628.
◦IMPROVED yaw rate sensors/lateral accelerometers have a part number of P/N 15220053.
Hope this helps.
beamn7 is offline   Reply With Quote
