11-30-2015, 07:11 PM | #1 |
R12 Pricing, and what is "12A"
After a long thread and helpful deciding on R12 vs R134, I was all set to make the decision to have my all-new-parts-but-stock AC system filled with R12, but it's $160 a pound, and we need about 4 pounds. With no guarantee that it won't leak, that's a pricey gamble.
I see "RED TEK 12A" for sale cheap on eBay (more like $14 a pound): Amazon.com: RED TEK 12a Refrigerant 20 Lb... But what the heck is 12A? Sounds like a name they made up, because it doesn't anywhere say that it's real 12. That's a 10X price difference, so can someone educated me on the differences? My system also already had the 134A connectors on it, so I think it may have had a conversion done in a previous life. LMC said the reman compressor (stock style) is compatible with 134A. They didn't know anything about the oil inside or whether its compatible, but you'd assume it has to be if the compressor is listed as compatible...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-30-2015, 07:18 PM | #2 |
Re: R12 Pricing, and what is "12A"
Dave, look into Freeze 12 if you can find anything about it. It is a R-12 replacement and I used it A LOT in the late 80's early 90's. I used to buy the freon at 99 cents a can and now it is that high WOW. But after the shake up and the freeze 12 came out I used it in over 100 trucks i built and never had a related A/C problems. Jim
11-30-2015, 07:20 PM | #3 |
$160 a pound is beyond robbery, that's just plain insane. You can find it on Ebay, Craig's list, and at Swap meets for $20 to $30 a can. Last year I bought a sealed case of genuine Servcon R12 ( 12 cans) for $30 total.
http://www.ebay.com/itm/7-12-OUNCE-C...NWViVc&vxp=mtr
"Negative people always seem to have a problem for every solution" |
11-30-2015, 07:24 PM | #4 |
Moderator
$160 a pound!? Where are you buying from? Here's some on eBay for wayyyyy less: http://m.ebay.com/itm/12-OZ-CANS-R12...478?nav=SEARCH
I bought 5 cans for $10 a can at a swap meet last summer. Look around, you can find it reasonably priced. Since most people have gone the 134 route demand for R 12 is in the toilet and you can get it priced a lot less than several years ago.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-30-2015, 08:26 PM | #5 | |
11-30-2015, 10:26 PM | #6 |
134a was $90 for 30 lbs.
1970 GMC Sierra Grande Custom 2500 265/70/16, th400, 502ht |
11-30-2015, 11:31 PM | #7 |
Keep watching Craigslist. I got a 30# sealed cylinder off Phoenix Craigslist a couple years ago for $250. You may not match that but keep looking.
Jim EDIT: Here's one pretty close to you. http://seattle.craigslist.org/see/mat/5337872855.html A partial http://seattle.craigslist.org/see/pts/5337828355.html Search the Craigslist of your choice for R12. Last edited by FirstOwner69; 11-30-2015 at 11:40 PM. |
12-01-2015, 08:56 AM | #8 |
http://67-72chevytrucks.com/vboard/s...d.php?t=586474
Simply stated, no way you should use any blend. Either use R12 or R134. R12 is still out there and it is nowhere near the prices predicted when it was discontinued.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-01-2015, 11:25 AM | #9 |
+1 on R12. Stay away from the drop-in blends. Also, you should consider the fact that a marginal front seal on an old or even rebuilt A6 compressor will/might hold a vacuum, but fail in short order when under pressure. This will cause you to loose your expensive R12 charge.
My advice: Purchase a NEW A6 form factor replacement compressor. Lighter and more efficient is an added bonus. |
12-01-2015, 11:37 AM | #10 |
I converted my stock ac to 134 a year ago and it works great. Stock compressor too. Even drove it to Vegas in August comfortably. I would convert it and go.
1971 Chevy Custom Camper/20, Hugger Orange with White Top 31,000 original miles (when purchased), 402, TH400, PS, PB, AC As of May 2017 it now has a turbo LS in it! (Still looks stock though) |
12-01-2015, 01:20 PM | #11 |
Personally I'd stay away from the 12a drop in replacements. Most of them are butane / propane.
12-02-2015, 08:01 AM | #12 |
Don't know how much they have. http://columbus.craigslist.org/pts/5302390792.html
05-19-2017, 03:27 AM | #13 | |
It-s The Only Ride I Have With R12 Was Still In It But No More R12 Now Its R12A And Its Super Cold BRRRRRRRRRRR I Live In South Florida So I Need That COLDDDDDDD Thanks For Your Input Harley03joe |
05-19-2017, 08:27 AM | #14 | |
05-19-2017, 10:03 AM | #15 |
It's a lot harder to vaporize gasoline than butane or propane.
Funny how the new 1234yf refrigerant is flammable and is being embraced by some.
05-19-2017, 10:29 AM | #16 |
Just FWIW I started this thread and it was a couple of years ago - I've had R134A in the system since then.
It leaked out once through a bad compressor seal in a new/reman compressor. That would have been all my R12 if I'd done that! New compressor (painted black to match) and it's been fine since and cools well too!
05-23-2017, 11:53 AM | #17 |
Keep your eyes open. I bought 3lbs of R12 in a full sized tank for about $150. I also bought a sealed, full 30lb tank for $400. I bought it mostly for personal use in my truck...completely restored the factory system.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
05-24-2017, 06:40 PM | #18 |
2 months ago, I purchased 4 cans on eBay for $75, to use in my 79 Trans Am. There is lot's of it on eBay. Demand is going down, because it's been so long since is was last used in new cars.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
