Old 02-25-2016, 06:41 PM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
If you like destruction -
then is thread is for you! I've been too butt hurt to post much about this yet, but a couple of weekends ago I hurt the motor (.060" over 454 bbc) in my '69 during a little test drive after installing a new AGR power steering pump and steering box. I hit an empty side street, hammered down on it in 2nd gear and spun it up to about 6500 rpm. Right when I let off for the stop sign coming up, I heard a metallic 'ping' (the expensive sounding one!) and immediately clutched it. The engine died as I clutched it and I coasted to a stop in a nearby parking lot. Long story short, I walked home, grabbed my daily driver and my trailer and towed it home. When I got it into my shop, I could see oil and a little coolant dripping out of the tailpipes - not good. No visible signs of anything exiting the block and no oil spray underneath. I left it sitting in the shop for a couple weeks too disgusted to mess with it. I finally got to pulling the spark plugs and found #1 hammered all to hell, coolant poured out of #4, 6 & 7, and #8 was soaked in clean oil. Needless to say the thing is toast, I'm hoping I can save some of it, since I had quite a bit of cash tied up in the valvetrain & heads (custom hyd roller, Crower rockers & springs, etc).
The thing only had about 1200 miles on it. The shortblock was machined and built by a local rebuilder, and after I had the work done I spoke to a few guys around town that said this guy doesn't have a great reputation for building hi-perf motors. An expensive lesson, but those are the ones you learn from or so my dad always told me when I was a kid. It had a couple annoying leaks right from the get go, and seemed to run hot more often that not, despite dual Derale electric fans and a big 2 row aluminum radiator. Just goes to show that if something doesn't seem right, chances are there is trouble ahead. I was easy on it for the first 500 miles, but drove the hell out of it after that. I'll be pulling it all out this weekend to disassemble it, hopefully I can do it without beating the heck out of the engine bay that I worked my a$$ off to get to my liking. I already have another bullet in the works, and no, it's not an LS engine.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-25-2016, 06:50 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: If you like destruction -
Ho-lee-crap... I'm sorry to hear. Beautiful truck.
With that much metal in the oil... something was failing for quite awhile before the ping heard round the world.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-25-2016, 08:57 PM   #3
PGSigns
PGSigns's Avatar
Looks like it dropped a valve. Have you pulled the valve covers? I dont think that is a short block problem.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-25-2016, 09:05 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
I'll get some more pics when I get it all apart. Looking at the plug, it does look like a valve hit the plug sideways, as there is a pretty defined edge gouged into the plug. On the bright side, it will be fun for all of us to play detective after the 'evidence' is posted up! I'm sure we can get a good idea of what ate what after the weekend.
I had changed the oil at 500 miles (Lucas break in oil) and again at 1000 (mobil 0w-40) just for good measure without any 'glitter'. No telling what may have happened in the 200 miles since.
Adam
Old 02-25-2016, 10:02 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Sorry to hear about that. In to see the evidence though.
Old 02-25-2016, 10:04 PM   #6
Boog
laying low
Boog's Avatar
Man, Adam, that's a damn shame right there. You cannot help but second guess the guy who machined and built it or the parts used in it. But sometimes you can do everything right and still something goes wrong. Better to find out close to home rather than out on power tour or something like that.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-25-2016, 10:15 PM   #7
cableguy0
I vote short block ripped itself apart from the rpm due to poor balancing. I wouldn't have much hope for saving anything other than the valvetrain. Hopefully the connecting rods stayed connected aren't weren't able to tag the camshaft. That engine bay looks great and its a shame to yank that engine. Please take pictures and keep us updated. Im curious as to what failed and we can probably figure out the cause.
On a side note my very first experience with an engine builder was terrible. I was 15yrs old and dumped every dollar I made into a bottom end that lasted 500 miles before it turned 2 connecting rods blue, spun bearings and broke a main cap from being so out of balance. I feel your pain however the place I ended up going to for the next one was the place I ended up working at and learning a huge chunk of what I know. I ended up running the speed shop there as well as being a general mechanic and learning machine processes and the proper way to do things. I might have pissed away 1000 bucks on the first short block but that was a damn cheap education for the knowledge I ended up with in the end.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-26-2016, 01:31 AM   #8
'63GENIII
'63GENIII's Avatar
On a side note my very first experience with an engine builder was terrible. I was 15yrs old and dumped every dollar I made into a bottom end that lasted 500 miles before it turned 2 connecting rods blue, spun bearings and broke a main cap from being so out of balance. I feel your pain however the place I ended up going to for the next one was the place I ended up working at and learning a huge chunk of what I know. I ended up running the speed shop there as well as being a general mechanic and learning machine processes and the proper way to do things. I might have pissed away 1000 bucks on the first short block but that was a damn cheap education for the knowledge I ended up with in the end.[/QUOTE]
Damn Adam that's terrible. On the bright side, your truck is wicked cool looking! Take your time on the next engine and it will be perfect.
Cableguy, your story brings back painful memories from my first engine 30 years ago when I was 17. Big shop, fast talking bums. Took every cent I had. Might have got 600 mi. out of it. Still pissed. Next shop was a local Bonneville engine guy who worked out of his garage (with a small machine shop in it) around the corner from my folks house. Cub Barnett. He taught me patience. That engine is still running today. Painful lessons that some of us have to learn the hard way.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-25-2016, 10:30 PM   #9
toolboxchev
Boy I felt that also, that is one heck of a nice truck.
This next one maybe you will have some more of your own hands in it. I know what I did when I make a mistake and usually find my errors.
toolboxchev is offline   Reply With Quote
Old 02-26-2016, 12:58 AM   #10
slotard
I hope you can at least salvage a reasonable number of parts.
I also hope your plans are bigger, at least a 502... a 540 would be nice and should fit the same as what you have now.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-26-2016, 11:58 AM   #11
Keith Seymore
Keith Seymore's Avatar
...so would a 572...
...as would a 624....
Very nice truck, btw..
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-26-2016, 09:34 AM   #12
jjzepplin
jjzepplin's Avatar
In for the carnage!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-26-2016, 01:44 PM   #13
slotard
Tall decks don't fit quite the same as short decks. Not saying they can't fit, just that they're a little taller and a little wider, and will require intake manifold spacers and some exhaust work. Not a huge problem given the likely cost.
1973 C20, 350/350
Old 02-26-2016, 08:38 PM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
You guys are obviously "smelling what I'm steppin' in", slotard - you are right in line with me. I put down the deposit on my next engine yesterday, and I will be staying with a short deck block, specifically a Dart Big M. It will be a 4.6" bore and 4.0" stroke motor (get out those calculators and figure the inches!) with a 6.535" rod and lightweight forged crank. I always had my heart set on a 502 way back in the day when they first came out, and even more so a 540 after those became popular. But when I started building the truck it already had the 454, so I used that block as my base and here we are. If it were a mild build, I'd screw it together myself, but a man has to know his limits, so I'm leaving this one to the pro's - Foxwell Motorsports/Straub Technologies will be handling this one. Amateur hour is over!
Most people will question why not a 4.25" or 4.375" stroke to make a 565/572/582, and that is a valid point, but I'm a fan of rpm's and a 4" stroke with 500+ inches will be give me plenty of torque and still be able rip up to over 7k in the blink of an eye. I'm basically building an engine with the same rod ratio & bore/stroke ratio as a bb 427 or even a small block 350, but with a lot more cubic inches. It will be a lot of fun, and I'll post build info and pics in another thread. But for now, I gotta get my butt out to the shop and get those wrenches spinning! I'm including another pic of that spark plug after I wiped all the metal fragments off. Man that thing is beat!
Oh yeah, got a couple more changes going on while it's in the shop; the CPP control arms in the truck now are nice, but the way the front wheel sits back in the wheelwell just bugs the hell out of me, soooo......
Adam
Old 02-26-2016, 11:56 PM   #15
slotard
That'll be a 532 right?
What crank/rods/pistons? Long rods absolutely help, there isn't much downside as long as you can fit the rings on the piston.
That should be a lot of fun, and a bigblock at 7k sure sounds nice. Your truck is reasonably light, so something with that size bore and only the stroke of a 454 ought to move you well enough.
Any ideas on heads/cams?
1973 C20, 350/350
Old 02-27-2016, 11:12 AM   #16
haysonj
haysonj's Avatar
I had a 454 that a local machine shop did a valve job for me and within 50 miles it did that to one cylinder. It dropped a valve and beat up the spark plug before I got it shut off. It also scored the cylinder so bad I had to sleeve it. The machine shop tried to tell me it was due to a broken guide but I'm sure they had some kid doing assembly and he didn't get the keepers seated right
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-27-2016, 11:29 PM   #17
storm9c1
*** That's interesting ***
storm9c1's Avatar
Many of us started wrenching because somebody else was incompetent and cost us money at one point or another. So we feel your pain. Nice rig, can't wait to see more carnage, and of course, the improved finished product. Glad you are jumping back on the horse and getting it done right. That's the attitude!
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-28-2016, 12:18 AM   #18
indymachinist
Wonderful looking truck. I'm going to have to agree with a few posters here that it dropped a valve and smashed it to bits in the cylinder.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 02-28-2016, 12:23 PM   #19
Coley
Coley's Avatar
Smile Re: If you like destruction -
Yeah...trouble for sure....you definitely need to replace that spark plug......
Seriously tho'...tough to hear about that.
Do you have any recourse with that engine builder with that thing giving up with only 1200 miles on it?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-28-2016, 09:34 PM   #20
BossHogg69
motor exploder
BossHogg69's Avatar
Well, you have to see the humor in this... I found an intake valve IN the intake!
I've almost got it all unhooked, should be ready to pull her shortly.
Adam
Old 02-28-2016, 10:19 PM   #21
Ta12sec
Once upon a time in my youth I built a motor from scratch. New block, new crank , new rods, new Pistons, fancy new complete heads only recycled parts were the timing cover and the oil pan. I babied the motor for 1500 miles. Started getting down on it and 500 miles later a easy burnout she stopped. Fired it up and made terrible noises, ran horrible and pumped coolant out the exhaust. Took it home and it looked like that. Found a valve had broken about an inch below the keeper. Valve fell down and windows the piston and the block. Obviously a parts issue. I lived near the big name brand head mfg so went to their store they looked at it and said yep we had s few of these. Guy went in the back and came back with one new head.... I asked what about my short block, he said that was he could do was one new head... I almost fed it to him. Went home cut the car up with a Sawzall and swore off hot rods for a full 3 months till I bought the next one......
Ta12sec is offline   Reply With Quote
Old 02-29-2016, 03:32 AM   #22
BossHogg69
motor exploder
BossHogg69's Avatar
Well it's out, but I didn't tear into it. All the valve stems are still in the retainers, I gave it a look since I had to pull the valve covers to get enough clearance to clear the firewall recess. I peeked inside and it looks like the cam and lifters are intact. Distributor gear looked good too. When I drained the oil, close to a gallon of coolant came out first. I didn't see any metal in the oil, and no chunks of anything in the screen on my drain pan.
I found a couple other issues along the way that need to be addressed also. The 'nice' Derale fans have started cracking around the edge of the bracing that holds the fan to the shroud. I've pretty much reached the consensus that Derale stuff is JUNK. The relay I got with the fans was dead out of the box, now this. I'm a little pissed, since now I have to take the fans and shroud apart and all this stuff has been painted, just one more thing to deal with. The temp probe in the radiator was also broken too. No wonder the fans weren't turning on/off like they should've.
I'm trying to post pics, but I keep getting the 'missing security token' prompt on both my PC & phone.
Adam
Old 02-29-2016, 10:55 AM   #23
ERASER5
ERASER5's Avatar
You need Chucky Cheese tokens. They work just fine, or you could just resize the huge pics on your phone.
As far as your engine, sorry for your loss. My engine is still down. it need heads after being rebuilt by the "the best guy in the state." Um, maybe not. #2 exhaust valve roached all the way to the rocker, rocker tip roached, all seal damaged or gone. I should have just bought new.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-29-2016, 10:30 AM   #24
SnS C10
SnS C10's Avatar
for some reason when I try to upload more than 2 pictures at a time from my phone, I get the same security token message. what are you planning on doing with the engine your pulling out?
SnS C10 is offline   Reply With Quote
Old 02-29-2016, 06:22 PM   #25
slotard
I prefer hosting my pics on another site. imgur.com is an easy one.
1973 C20, 350/350
454, bbc, big block, big block chevy
