Old 05-22-2016, 04:36 PM   #1
52ratrod
Question Using UMI performance A-arms on S10 frame swap
Hey guys, First thank you to everyone that has posted. all his information helps so many of the newbies. I have a question about a s10 swap I'm going to be doing on my 52 chevy 1300 3 window. I know that with the front end that not only to replace the bushings and all other worn parts that normally a 2" wheel spacer is used to bring the wheels closer to the fenders
I want to go with a more modern look and upgrade my a-arms to the umi performance a-arms they offer.
Has anyone ever gone to a tubular a-arm and which one to avoid using a wheel spacer?
Dallas
52ratrod is offline   Reply With Quote
Old 05-22-2016, 08:46 PM   #2
Coupeguy2001
Coupeguy2001's Avatar
Re: Using UMI performance A-arms on S10 frame swap
check speedway in Lincoln Nebraska. Checkout their race car catalog,
They have dimensions and u-build-it ones.
Coupeguy2001 is offline   Reply With Quote
Old 05-23-2016, 11:41 PM   #3
tmoble
UMI stuff is good, but you'll need both upper and lower arms to match. You'll also need longer tie-rods.
If you really,really want to do this Speedway Motors would be a good place to start.
Maybe deeper offset wheels?
tmoble is offline   Reply With Quote
Old 05-24-2016, 12:15 AM   #4
52ratrod
Im going to do a frame swap with a 2002 extended cab so once I can get my hands on a ford 9" or s10 4x4 rear end to update the brakes and change the stock rear end ratio.
From what I can read on is that spacers are needed on the front to even it to rear once I get a wider rear mounted.
If I go with umi top and bottom a-arms and drop spindles will that bring me out enough so front spacers are not needed.
Old 05-24-2016, 12:39 AM   #5
tmoble
Sounds a little strange, maybe you investigate this further.
UMI stuff will be stock width.
I think you'd be money and work ahead to use a narrower rear that's similar to the stock width. re-engineering a front suspension and steering is not an easy (or smart) deal. There's lots of stuff available to make this work, no need to re-invent the wheel here.
Old 05-24-2016, 11:04 AM   #6
52ratrod
Michigan metal works offers upper and lower a arms from 1.5 to 3 inch each side and relocate the shock off the frame through the upper to connect to the lower. Has anyone had success with these?
performance, s10 swap, suspension, umi
