Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-24-2016, 10:57 AM   #1
rdauphinais
rdauphinais's Avatar
c5500 350 to 6.2 swap
Hey everyone, I will be buying the 72' C5500 as soon as my car sells. It has a 350 Chevy in it backed by the sm465, and my buddy has a 6.2 diesel for little to nothing. This isn't my first time around the 6.2's and 6.5's, i know they are no power house, but thats fine. What i need to know is what will I need to swap the two? Will the flywheel off the 350 bolt up to the 6.2? And il have to run a separate g.p. relay system.
rdauphinais is offline   Reply With Quote
Old 05-24-2016, 12:34 PM   #2
rkn463
rkn463's Avatar
Re: c5500 350 to 6.2 swap
I'm not sure about the flywheel, you may want to check in the diesel section on this forum regarding that part. I do know that the bell housing bolt pattern is the same and it is a direct bolt in on the motor mounts. Make sure to share some photos with us when you get it.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 05-24-2016, 12:48 PM   #3
rdauphinais
Thanks for the reply, I was unaware we had a diesel section, i guess ill have to look for that.
Old 05-24-2016, 04:22 PM   #4
luvmytruck
I am pretty sure that the 6.2 is externally balanced having rebuilt two of these. I recall the flexplate having a large weight spot welded to it. you would have to have a flywheel for a 6.2. I am also aware how gutless these are and would suggest a duramax instead. You would have 3x the power and the same mileage.
luvmytruck is offline   Reply With Quote
Old 05-24-2016, 05:11 PM   #5
rdauphinais
I'm not a big fan of Duramaxes, but if I did that, would it bolt up to my transmission? And If i swapped in a more modern diesel engine, it would be a Cummins or Powerstroke swap. Im looking for this to be a pretty simple swap. And i always liked the 6.2 idi's for some reason.
Old 05-24-2016, 06:44 PM   #6
jumpsoffrock
Not knowing much more than Powerstroke= Ford and Duramax=chevy, what exactly are the main differences between them that makes one better than the other?
You can tell I don't know my diesels.
jumpsoffrock is offline   Reply With Quote
