Old 08-21-2016, 05:11 PM   #1
mikecaddy500
mikecaddy500's Avatar
Exclamation 1972 CUSTOM Camper with coil springs
My 72 c20 has coil springs and the trailing arms are rusted out. All the replacements are listed for 1/2 tons. Are they the same?
mikecaddy500 is offline   Reply With Quote
Old 08-22-2016, 11:14 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1972 CUSTOM Camper with coil springs
Technically the 3/4 ton arms have an extra plate riveted to the top of the arm from the axle end up to the spring mount. This was to provide extra support to the arms since they are likely to be worked harder.
If you're not using your truck as a work horse, you can use the 1/2 ton arms.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-22-2016, 12:43 PM   #3
mikecaddy500
