![]() Join Date: Nov 2001
2001 3500 Dually Lowering ?
Anyone in here have any experience or pictures of a 2001-2002 (or 2003-2007) 3500 dually that has been lowered. I don't want to go too extreme as I still will use this to tow and haul. I want to avoid air suspension also.
Its a 2wd but this thing looks like a 4x4. Thoughts? Input? Ideas ?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
Re: 2001 3500 Dually Lowering ?
Anyone ?
Customization is what you want it to look like -- not what other people think it should look like |
![]() Join Date: Jun 2016
Go with air - you won't regret it.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
when it comes to the 99-07 trucks 3/4 and 1ton I perfer DJM suspension. they make nice stuff that bolts together well and holds together. I have a 4/6 drop on my 4x4 duramax drag truck and it has held together really well and rides nice too.
how much do you tow? you can still tow with a significant drop but youll want the right helper bags to compliment the system. dont just go all air ride you need some form of spring if you tow heavy. |
#6 | |
Add an AOL kit if you need more drop but want to ensure it maintains it's hauling capacity.
#7 | |
i have DJM lower control arms that dropped the front end 3" on my 2500HD for the rear i did shackles and hangers, id start with shackles first though and decide how low you wanna go. |
#8 | |
The 2500(8600 GVW) 2wd had coil springs. The 2500HD/3500(9200 GVW+) 2wd had torsion bars
