Old 03-08-2017, 01:39 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
292 Pistons
I'm sending my 292 to the machine shop later this week and started looking for new pistons and there are 5 different stock replacement options on Summit alone.
Any opinions/suggestions on the following? Any other pistons that are better?
I want to run 87 so that is why I am looking at stock pistons.
Thanks in advance.
https://www.summitracing.com/parts/u...make/chevrolet
https://www.summitracing.com/parts/s...make/chevrolet
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-08-2017, 10:09 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
Thanks in advance.
All those pistons are .030 over just to be clear. Few of them have different compression distances. https://www.summitracing.com/parts/u...make/chevrolet
I'd just go with these.
Old 03-08-2017, 11:53 PM   #3
Classic v6 GMC's
Re: 292 Pistons
Thanks for the reply!
Yes I was just looking at .030 over because that is a common over bore. I'm going to wait for the machinist to tell me what size is needed.
I saw the different compression distances and dish sizes and that is why I wanted suggestions.
Any reasons for those pistons over the other? Just wondering.
I am building this for my 4x4 so I want to keep the low end torque.
How much would 1.84 or 1.94 intake and 1.6 exhaust valves help?
What about lump ports?
I plan on going with a 4 barrel intake.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-09-2017, 03:19 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
I'm not sure what the stock distance was so I picked the furthest. haha Personally I'd prefer sealed power pistons over those, but you can only get cast aluminum propane pistons from them which would bump your compression to 9.5.1.
With stock compression and a stock cam bigger valves with lump ports won't do a whole lot. 1.84's with lump ports would help for sure, but adding some lift would be the best thing you could do.
Here would be a good cam:
http://www.compcams.com/Company/CC/c...x?csid=58&sb=2
This is a 250 cam so you'd have to have it custom ground on a 292 cam.
4 barrel intake with headers would help to. You'll get better mid range with them.
Really the best thing you could do is bump the compression up for more power, then you would have the low end still. 5-8 pounds of boost would really do it.
Old 03-09-2017, 07:21 PM   #5
Classic v6 GMC's
Re: 292 Pistons
Okay I dropped it off at the machine shop and he said we need .040 over pistons.
Can I get .040 over propane pistons? So I would have to run 91?
So if that cam, 1.84 and 1.6 valves, lump ports, 4 barrel and header will make a nice engine then I will do that. Just not sure on pistons.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-09-2017, 10:16 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
If it was me I'd go with a .040 over set of Ross pistons...but those will put you out $620. lol
Another issue is the sealed power pistons are only available in a .030 over bore.
If you can't find pistons you can shave the block and head for more compression. I shaved the head on my 292 .030. Block you'd have to be more conservative with. Any particular reason why you have to go .040 over???
Old 03-09-2017, 06:41 PM   #7
GRX
GRX's Avatar
Re: 292 Pistons
The #1437 would be my choice as well.
How would one deal with different fuel pump eccentric location using that 250 cam? Electric?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-09-2017, 09:48 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
You can't use a 250 cam in a 292, that eccentric will hit against something and for the life of me I can't remember, OR it was the fact that you Can, but you won't be able to run a cam driven pump.
Old 03-09-2017, 10:14 PM   #9
GRX
GRX's Avatar
You are probably thinking of flat spots on the 292 cam for conn rod clearance. That would be chief concern using a 250 cam.
Old 03-09-2017, 10:17 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
That and I thought there was a reason you couldn't as well due to the position of the eccentric. I'll have to read up on that again.
Old 03-10-2017, 12:00 PM   #11
suville
suville's Avatar
Re: 292 Pistons
Sealed power pistons are available in .040 over I ended up with a set Im not going to use, decided to bite the bullet and get the Ross pistons from Tom
suville is offline   Reply With Quote
Old 03-10-2017, 01:55 PM   #12
Classic v6 GMC's
Re: 292 Pistons
The propane or stock style pistons?
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-10-2017, 02:46 PM   #13
Classic v6 GMC's
Re: 292 Pistons
Which lump ports would you suggest?
http://www.ebay.com/itm/HI-FLOW-inta...KVwYcw&vxp=mtr
http://www.ebay.com/itm/T6G1-230-250...hRZ9on&vxp=mtr
http://www.ebay.com/itm/T6G2-Max-Flo...RRXv3F&vxp=mtr
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-11-2017, 12:25 AM   #14
Classic v6 GMC's
Re: 292 Pistons
Well .040 over was confirmed by the machine shop so I guess I will go with these https://www.summitracing.com/parts/uem-1437-040
I guess I can always put a turbo on it.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-11-2017, 01:48 AM   #15
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Pistons
Those 3 are pretty much the same, I'd get the ones in the 2nd link.
Sounds good, turbo would be good with the stock compression.
