Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-13-2017, 10:58 AM   #1
1966burb
1966burb's Avatar
Need special bolt for jump seat for 66 burb
I know this is a long shot, but throwing it out. I need one special bolt for the pivot or hinge point on my passenger folding jump seat on my 66 burb. The part that is special is the shoulder under the head of the bolt. I have searched shouldered bolts and have found nothing close. I may have just make a sleeve that slides on the bolt but OD dimension is odd so it will need to be turned down on a lathe. Hoping someone has a rusted out or broken frame in their special junk that has the bolt I need.
1966burb is offline   Reply With Quote
Old 04-13-2017, 03:08 PM   #2
Southcity
Southcity's Avatar
Re: Need special bolt for jump seat for 66 burb
Curious to know if the bolt in your pic is stripped and unusable? if not and it's just a bit rusty it would be easy to restore it to like new condition. Or is it that you only have one and need more than that?
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-13-2017, 08:52 PM   #3
1966burb
1966burb's Avatar
This is the good one. Other one is broken. J
Old 04-13-2017, 09:11 PM   #4
Southcity
Southcity's Avatar
Thought that might be the case, good photos and drawing btw. Agreed that to match exactly would mean either someones rare spare parts bin or salvage yard. The alternative would be to find something that looks the part and functions as the stock piece with little to no modifications. I'm sure others will chime in too, here is a link to PIC which has both stock sized and custom made precision shoulder screws:
http://www.pic-design.com/precision-...er-screws.html
Old 07-12-2017, 09:29 AM   #5
1966burb
1966burb's Avatar
Still looking for one bolt. I may just have to find something close and have it machined to match.
Old 07-12-2017, 01:55 PM   #6
pimpston65
pimpston65's Avatar
i know of a spot where such a bolt is to be had!!! is it the bolt that attaches to the front two curved legs for the jump seat? if so i can hit this place up this week end...
pimpston65 is offline   Reply With Quote
Old 05-30-2018, 07:49 PM   #7
jessicaJHRS
I am SO glad that you posted this. I have run into the same problem today with my 66 suburban. I have searched high and low for a screw identical to your photo. My problem is that both sides of the jump seat was NOT the same. so even if i wanted to reuse the hardware, ive only got one matching screw. If anyone has any spare's id be happy to take them off your hands!
jessicaJHRS is offline   Reply With Quote
Old 05-31-2018, 12:23 AM   #8
padresag
if you happen to read the line just above you will notice that I said that I had 3 of them
ron
padresag is offline   Reply With Quote
Old 05-31-2018, 12:36 PM   #9
jessicaJHRS
fortunately last night i stumbled across another screw identical to that one. Weirdly it was a trim screw that was being used on the molding inside the cab above the drivers side door. But if for some reason i need one, i will shoot you a message. Thanks for the reply
Old 06-04-2018, 03:24 PM   #10
1966burb
1966burb's Avatar
Sent you a PM about 1 bolt. Jim
Old 06-04-2018, 05:55 PM   #11
jessicaJHRS
uh oh! i dont see a PM in my inbox.
Old 06-04-2018, 10:35 PM   #12
1966burb
1966burb's Avatar
sent PM to padresag.
Old 06-27-2018, 10:43 AM   #13
1966burb
1966burb's Avatar
padresag -- Bolt arrived in great shape. thanks Jim
