![]() Join Date: Feb 2004
EZ wiring ignition switch wiring for dummys
Ok guys , I pulled my hair out for days and after many searches with no solid answers. I finally got it right and am posting this for others to reference. Note: if you swap the brown ign and the orange acc. Your fuel pump will run in acc mode and ign on so dont do that. Also you dont need the black piggy power but the 67-72 switch has an extra lug so you may as well keep it. Also the terminals in the ez wire kit are the same as the ones in the 67-72 plug. They are a gm series 56 and can be found at orylies in the 12 gauge size to make a clean splice free install on combining the coil/ign brown wire. On more note the 67-72 switch will fit the 61-66 dash and use the stock nut. You will need a flat washer to space it behind to get it tight. This will give you the acc function.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
