Truck 12B Rebuild package with gears and limited slip $775
Complete rebuild/regear package for your truck 12B
Gear ratio of your choice. Yukon Duragrip Limited slip differential. (3.73+) Auburn, and eaton 3.54 down carriers also available. Axle bearing and seal kit. Master differential rebuild kit. Complete with all bearings, races, seals, ring gear bolts, marking compound etc. Order through the 19th of May and receive a $40 mail in rebate on the Yukon Duragrip.
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside Last edited by LockDoc; 11-10-2019 at 12:01 AM. |
Re: Truck 12B Rebuild package with gears and limited slip $775
I know this is a year old but do you have something like this for a 10 bolt?
![]() /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
Thats ok, Im still here and still offering deals on drivetrain parts! I can certainly put a package together for the 10b. What ratio are you looking for?
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside |
3.42 or 3.73. Prefer 3.73. I'ts a 10b out of an 84 C10 that sat up about a year before I got the rear axle. It has the 28 splines and an open diff. I'm going to have it narrowed 1.5" per side. Since I'm having that done, I'd just like to install a traction lock unit, different gear set and replace all bearings and seals.
Just checking in.
Also interested in a package for a 10 bolt for an 05 Sierra.
3.90 R&P Eaton or Yukon LSD Bearing, race, seal, and gasket kit
#7 | |
YUkon master install kit $153 YUkon gears, whichever ratio $253
![]() Join Date: Aug 2004
Price for the Duragrip LSD only??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Looking for a 12B true track with an install kit. Current gears are 3.73s.
$663 to your door
Yukon Duragrip, install kit, and 3.42 for 1980 12 bolt price please.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
