Old 06-06-2017, 02:14 AM   #1
trucksforever
Gas tank rusted out on 87 gmc suburban 4x4
Does anyone know how to remove a gas tank off of a 1987 GMC suburban 4x4 1/2 ton? Tank rusted out and this is my first time doing it. If anyone has any tips, it would be greatly appreciated?
trucksforever is offline   Reply With Quote
Old 06-07-2017, 04:44 PM   #2
Nodnarb76
Nodnarb76's Avatar
Re: Gas tank rusted out on 87 gmc suburban 4x4
I have done this job a few times on my Suburban.
Support the gas tank with a jack. The gas tank is held into place with two metal straps. Remove the two bolts at the front of the straps (please make sure gas tank is secure). You should then be able to move the straps to the rear of the truck and out of the way. lower the jack/gas tank just a little to be able to get to the top of the gas tank. Remove the negative ground lead for the fuel pump it is bolted to the frame. Unplug the fuel pump connector. remove the fuel filler and vent hoses, fuel supply and return lines.
After everything is disconnected should be able to lower the tank out of the way.
I took a pic last year when I was doing this job. Hopefully the pic may help too.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 06-08-2017, 06:10 AM   #3
trucksforever
Thanks for the pics and information Nodnarb76.
Old 06-10-2017, 10:01 AM   #4
Ski-me
Ski-me's Avatar
I also did this job a few times. Yes on the jack in the middle but it's hard to balance.
I used two sets of come-a-long straps on each side. Used the jack to support in the middle, loosened each strap evenly, dropped tank a bit and repeat.
I was able to walk the tank down by myself several times with a 1/2 tank of gas.
Several times means: leaking new tank, pump not working, pump not working.....discovered my electrical connector was soldered so re-did connection.
Lesson learned.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
1/2 ton, 1987, 4x4, gmc, suburban
