Old 01-23-2018, 10:32 AM   #1
Snake72
Snake72's Avatar
brake booster recommendations
So I've been shopping for brake booster w/ master cylinder and prop valve combos and i'm seeing a lot of mixed reviews of the CPP and POL units. Leaking, poor fit, wrong rod, etc. Read a few good things about Tuff Stuff. Anybody have recommendation on direct replacement???
Truck is a 72 with factory power disc/drum. Old unit was leaking and I have literally replaced every single brake component on the entire truck, booster is my last piece.
Also, whats the difference between delco and bendix boosters? Do I get single or dual diaphram? stock 11" booster? I dont really want to drop 500 on a wilwood unit but they sure get great reviews
Snake72 is offline   Reply With Quote
Old 01-23-2018, 11:29 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: brake booster recommendations
Howdy Snake, when one of my 72's blew a diaphragm I took unit to an Oreilly's. The difference between a Delco and Bendix unit is in the stamped design of the case. Cant go wrong if you just match the design and diameter of the existing unit. I dont remember which one because it's been years, but i do remember the replacement unit will look exactly like the one that's blown. Pretty sure there's a core charge involved.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-23-2018, 01:20 PM   #3
Bigdav160
Bigdav160's Avatar
Dual diaphragm is more powerful than single and used on 3/4 ton trucks. Some people choose to use them on their 1/2 tons but they are physically larger and possibly uglier to some eyes.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-23-2018, 01:39 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: brake booster recommendations
x3 go to O-Reilly's with old booster and have them match it up. Dual diaphragm is best.
This is for a 71 but should be the same thing.
https://www.oreillyauto.com/shop/bra...rake%20booster
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-23-2018, 03:49 PM   #5
Snake72
Snake72's Avatar
thanks guys!
Old 01-23-2018, 05:23 PM   #6
demian5
demian5's Avatar
Get the biggest booster you can. I bought the 9" for my impala from CPP with the combo valve and master cylinder and am disappointed with the braking assist during the second application of the brakes. the first is fine, but an immediate again requires more pedal effort. AND when I first got it, the check valve was bad.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-23-2018, 08:55 PM   #7
elkniks
elkniks's Avatar
You also need to consider if you want the goldish factory style finish or if black is good. I am pretty sure I bought the Tough Stuff unit and it works fine. I am only running about 10.5 inches of vacuum and the pedal is a little stiff but not that noticeable.
elkniks is offline   Reply With Quote
Old 01-23-2018, 11:27 PM   #8
redbaron
redbaron's Avatar
Here is a link to a thread I posted a couple years ago on our K10 project. http://67-72chevytrucks.com/vboard/s...d.php?t=661200
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 01-24-2018, 10:20 AM   #9
Snake72
Snake72's Avatar
Thanks for the info guys, are the original bendix or delco units dual diaphram? Or was that 3/4 ton trucks? The way I understand it, delco are gold cad which I prefer, bendix are black, is this right? I know they have different patterns on the booster and I have my original in storage currently, so I'll have to look at it.
Leaning towards a tuff stuff or right stuff 11" delco style, are they a direct swap with bendix units if thats what I originally had?
I have not had the truck running yet since getting the motor built, mild 383 but the cam has 108 LSA so I hope it produces enough vacuum. Or I'll need to hit the squat rack and leg press a little more...
Old 02-20-2018, 09:11 PM   #10
Z10
Z10's Avatar
Here's my set up with a Tuffstuff and Willwood.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-23-2018, 11:46 AM   #11
68 P.O.S.
I bought one of these a couple years ago http://67-72chevytrucks.com/vboard/s...d.php?t=720837
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
