02-21-2018, 12:49 AM | #1 |
Gas milage help
I have a 1969 gmc longbed that I just put a new crate 350 in from jegs. I reused the original manifold and it has a late 70’s Rochester 2 Barrel carb on it. I believe it’s a 2vg. I’m not sure what the gear ratio is but it has been changed from the stock. Th 400 tranny. After taking for a few drives I calculated it getting 6.8 mpg. How in the world could I pull this up. I was wanting to drive it 60 miles three days a week to school. But it’s imposslibe with that kind of MPG.
Posted via Mobile Device |
02-21-2018, 01:28 AM | #2 |
Re: Gas milage help
I would check your ignition timing. Then check your carburetor adjustments.
These never did any good on fuel even when new. Vic |
02-21-2018, 01:32 AM | #3 |
02-21-2018, 07:27 AM | #4 | |
Re: Gas milage help
If you are looking to buy a new carb for the purpose of improved mpg, I would first consider one of these. https://www.summitracing.com/parts/fif-30003 Its a self learning fuel injection system, that will get you the best fuel mileage because when cruising, its constantly trimming fuel to keep the engine running at stoich air fuel ratio. You mentioned that your truck is a long bed, is it a 1/2 or 3/4 ton? What rear axle ratio does it have?
2012 GMC 2500hd/ 6.0 1972 Chevrolet c20 350/350 1986 Chevrolet Monte Carlo SS/ 6.0 lsx |
02-21-2018, 08:09 AM | #5 |
Re: Gas milage help
Something is off if your gas mileage is that bad. Even my hopped up big block 402 does better than that. It would help if you let everyone know some of the following; HEI or points, ignition timing (initial and full), plug gap and even what plugs your running, rear end ratio, manifold vacuum, and even pictures of your carb and engine. There are some very good mechanics on this site that can help. A 69 2 wheel drive pickup with a new crate engine should do at least 10 MPG, if not better. Just curious, why did you put a 2 barrel carb on a new crate motor?
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
02-21-2018, 08:50 AM | #6 |
Re: Gas milage help
350/auto/long bed should get about 10mpg so it's either your tune ,your rear gear ratio or your right foot that's bringing down to 6.8 . spending $800.00 on a different set up ...Well $800 buy's a lot of gas
02-21-2018, 09:01 AM | #7 |
At the body shop.
Re: Gas milage help
My cap and rotor where corroded terribly and seemed like the mileage went up a bunch after swapping those two parts
" That didnt make it any newer " " Dont antique the equipment " |
02-24-2018, 04:18 PM | #8 | |
Re: Gas milage help
My 5.3 swap does a consistent 17mpg although I had hoped for a little better, its still better than the 350/350 quadrajet I pulled out of it that only ever got 10mpg no matter how grandpa like I drove it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-24-2018, 04:50 PM | #9 |
Re: Gas milage help
When I got my truck it had a six with the single barrel, powerglide and 3.73 gears and got around 10 mpg. I put a Edelbrock 500 cfm four barrel on the six and got around 9.5 mpg. I am now putting a 454 in it with two four barrels and an overdrive auto. Will likely get around 9.5 mpg!
1968 SWB Step Side, Big Block, 4L80E , Running! |
02-26-2018, 11:53 PM | #10 | |
Re: Gas milage help
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-22-2018, 03:07 PM | #11 | |
02-22-2018, 03:13 PM | #12 |
02-21-2018, 09:11 AM | #13 |
Re: Gas milage help
After making sure that all the plugs, wires, timing etc is right, you may have the wrong jets in the carb causing it to run rich. Burning more fuel costing you milage.
02-21-2018, 10:24 AM | #14 |
Re: Gas milage help
You sure you don't have a fuel leak.. my 540 cid big block gets better than that..
02-21-2018, 11:43 AM | #15 |
Re: Gas milage help
My 68 C-20 got 8 mpg when I got it. 350 v-8 with auto and someone had changed the gears to 4.88's.It also ran hot in the summer. Found out it had a radiator from an inline six. Installed a new V-8 radiator,changed the rear end to 3.73's and did a good tune up and now I get 13-14 mpg. There is hope!
68' with no bells or whistles unless I add'em. |
02-21-2018, 12:14 PM | #16 | |
Re: Gas milage help
Hence the reason we don't see these things all over the roads anymore.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-21-2018, 01:03 PM | #17 |
Who Changed This?
Re: Gas milage help
There is something wrong with your setup. I'd bet most of it is going to be the timing. I have a 400/400/3.54 axle setup and I get 7MPG when towing a 26 foot long travel trailer. Did the engine come with a harmonic balancer and a pointer for the timing already installed, or did you have to add a pointer? I've seen those not be in the right place, and the timing ended either retarded or over advanced. How does your exhaust look? Getting a lot of blue or black smoke? That is an indication of loading fuel in the carburetor. You can look down the inside with the engine running and see if fuel is dripping. No need to blip the throttle when doing so.
02-21-2018, 01:14 PM | #18 |
Re: Gas milage help
I like those original 2bbl carbs on those, they run well and are economical. I would guess yours is wildly out of tune.
Properly set up I imagine you should get 12-14mpg in the city and maybe 18-20 on the highway. There will always be heroic tales of people getting 30mpg and so on but I'm talking about normal driving. You must have something fundamentally wrong with the carb. That's a good thing, because it can be fixed! Also the easiest way to calculate mileage is to fill it, drive 100 miles, and then refill. Don't try to measure consumption (as opposed to refilling), it's too inaccurate.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-21-2018, 01:22 PM | #19 | |
Re: Gas milage help
Another two cents... worth the price paid! J
White K20 |
02-21-2018, 06:42 PM | #20 |
Re: Gas milage help
Also since you have a new engine be sure you’re not running so rich that you’re flooding the cylinders with fuel. That won’t do your oil or your new bearings any good
02-22-2018, 11:37 AM | #21 |
Re: Gas milage help
Dave I just spit coffee out my nose laughing at 18-20 mpg with a long bed 69 GMC truck. No disrespect, so please don't get mad at me.
02-22-2018, 01:06 PM | #22 | |
Re: Gas milage help
I WOULD KNOW FOR FACT, I would be getting 30 MPG. Am i dreaming |
02-22-2018, 02:26 PM | #23 | |
Re: Gas milage help
It was a 1969 C10 with a 307 four speed, 2bbl (maybe monojet). Putz along at 90km (or 55mph). You really don't think a well-tuned truck can manage 18mpg on flat ground at moderate speeds? Once you start speeding up and slowing down you're looking at 14, in town 12, and driving hard 10. But highway cruise is pretty efficient. [Edit: I just looked it up, Regina is 1892 feet of elevation and Moose Jaw is 1893. It literally changes one foot in 50 miles... that's what you call FLAT] One semi-related thing I noticed was that my Range Rover Supercharged gets about 12-13 in town. But in mountain driving through Rainier, when keeping the speed down to 40, it was getting mid-20s. Aerodynamic brick and changes in speed, I guess.
02-22-2018, 04:59 PM | #24 |
Re: Gas milage help
Me too. A 2017 Silverado with a 5.3 and a 6l80 gets 16/22. A bigger motor with half the gears and a carb will never live up to that.
02-22-2018, 05:10 PM | #25 |
Re: Gas milage help
I have a 2015 with the 6-speed. 21 is best on long drives. pulling the toy hauler... 6-10
