05-05-2018, 05:39 PM | #1 |
1959 duel master cylinder with power booster
I would like to install a duel master cylinder with a power booster. The start of many questions to come is the transmission crossmember. I have an original 4 speed manual transmission. Do I have to replace the transmission crossmember?
05-05-2018, 06:15 PM | #2 |
Re: 1959 duel master cylinder with power booster
It will work with the four speed and cross member, just fine plenty of room
for the brake system to fit. |
05-05-2018, 09:16 PM | #3 |
I'm glad you posted this, I am wanting to do the same thing on my 59 with the original 235 and 3 speed transmission. Will it also fit my application as well?
05-05-2018, 10:13 PM | #4 |
I was wondering which company to use?
05-06-2018, 07:21 AM | #5 |
I got mine from Brothers,fit very well, easy install. Plenty of vendors have these units look for direct bolt on.
I think the three speed has a problem with linkage being in the way. Just look and see if you have clearance of about 8 inches from the frame out ,where old master cylinder is mounted. If you have the clearance it will fit. Last edited by sack54; 05-06-2018 at 07:26 AM. Reason: more info. |
05-06-2018, 07:42 AM | #6 |
If you are tight for room just use updated two chamber master cylinder no booster and add one of these to your system.
http://www.ecihotrodbrakes.com/brake...ultiplier.html Makes old brake systems work great ,take no room to install |
05-06-2018, 04:06 PM | #7 |
If I install the 2 chamber master cylinder and front disc kit without the vacuum booster will I see a noticeable difference over the stick drum set up? Or even just the front disc kit on the original master cylinder.
05-06-2018, 04:27 PM | #8 |
The stock master cylinder has one chamber .If you had a brake line let go no brakes
With the newer master two port if you were to loose a brake you still have other port to stop vehicle . front and rear are separated for this reason . Trucks and cars had disc brakes without power boosters. Better with booster and equalizer valve. |
05-06-2018, 07:00 PM | #9 |
Do I need residual valves as well and if so would I need them with the balance valve?
05-07-2018, 01:48 AM | #10 |
here is a little explanation of a brake system with some good pointers onhow stuff works and what stuff does.
http://www.hotrod.com/articles/brake...ot-rod-basics/ |
05-07-2018, 01:53 AM | #11 |
and a pic of what a hydroboost looks like
https://www.performanceonline.com/19...e-Booster-Kit/ |
05-07-2018, 01:55 AM | #12 |
and a couple of builds with the hydroboost on 55-59 chevy
05-07-2018, 01:49 AM | #13 |
05-07-2018, 01:52 AM | #14 |
05-07-2018, 02:32 PM | #15 |
look at orrieg's build, he remote mounted the booster/mc behind the x-member with a rod
as dsraven mentioned hydroboost is very effective at braking, i run one on my 58 truk
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-11-2018, 02:09 PM | #16 |
Called cpp yesterday and they said it wouldn't fit with the 4 speed manual because of the clutch linkage. They said the master cylinder alone would fit.
05-11-2018, 05:01 PM | #17 |
call Brothers I called ordered and installed the whole unit ,no problems bolted right in. Plenty of room .
If you want I'll get a picture of mine in place |
05-11-2018, 10:09 PM | #18 |
cpp also told me that their setup wouldn't fir in my '49 with an m21. said no room for the shift linkage. bought one just to try it & it fit with plenty of room.
05-19-2018, 06:43 AM | #19 |
It would be great if you can send me a picture. thanks so much...Anthony
07-08-2018, 09:07 AM | #20 |
hope these pictures hep you out
07-08-2018, 10:27 AM | #21 |
Dual diaphragm boosters have a smaller outside diameter, there seems to be plenty of room
07-08-2018, 07:45 PM | #22 |
Thanks Guys, I spoke to Sack54 and he guided me in the right direction.Ordered set up for the power brakes. I wanted all original but safety first.
07-08-2018, 08:02 PM | #23 |
Mine fit fine with the stock 3 speed setup.
07-10-2018, 11:40 AM | #24 |
I'm running a muncie 4 speed trans. I moved my master cylinder / booster under the bed behind the cab. The bed floor is raised 4 1/2".
07-15-2018, 09:32 PM | #25 |
Got the unit in and plumbed in as well. Special thanks to Sack54. I drove this guy crazy. Thanks Tom |
