05-08-2018, 07:31 PM | #1 |
Windshield Wiper Hell
As the title says, I am in windshield wiper hell. My first issue, the wipers only worked on hi... then, it only worked on hi once in a while, meaning, they wouldn't work most of the time. If I got out of the truck and gave them a tug, they would come on. Not optimal but... effective at the time.
So, I changed the turn signal/wiper switch. That didn't do it. Then, I changed the wiper motor, that didn't do it either - still the same issue. Now, I gave it a tug this morning (i know - sounds dirty - because it IS) and the whole wiper arm stripped on the grooved doohickey its pressed onto. I parked the truck and refused to talk to it - or I would end up abusing it with a hammer. (anger issues at this point). I looked for the wiper control module (based on other threads I have read) at the bottom of the steering column and there isn't one... Could it be the piece that the turn signal/wiper switch slides into? how hard is that to remove or get for that matter? What is it called? Also, do I have to replace the wiper linkage to replace the "doohickey" the wiper arm sits on? I cant find that piece separate from the $170 linkage... By the way, where I live in Hawaii, it's been raining since January - and oh, we have lava flow and earthquakes - I am sure you saw the news. They make it worse than it really is (ACID rain - ). I don't live in lava flow area - 10 miles away and above - but the earthquake was cool! Any advice on the wiper situation you could provide would be great... I do not need advice on where I live - yes I know I live on a volcano but, all of Hawaii is a volcano so... can't have rainbows without rain... I am still rollin & repn my c10 like I stole it!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 05-09-2018 at 02:55 PM. |
05-08-2018, 08:44 PM | #2 |
Moderator
Re: Windshield Wiper Hell
Base models don't usually have the pulse module at the base of the column.
Did you change the switch or just the stalk? You'd remember changing the switch... it's an unpleasant job. You have to pull the upper housing off. The wiper, turn/hazard, and cruise are separate switch parts. Cruise is in the stalk. Turnsignals can be accessed by just removing the lock plate. The wiper switch is only accessible after you remove the upper housing. You'll absolutely need a lockplate tool... this should take you to the series of five videos on tearing down the mid-80s Saginaw steering column. The videos are an early T400 CK chassis. Saginaw columns could be found in AMC/Chrysler Jeep, AMC Eagle, GM G-Body, GM CK, ST, RV trucks and many more vehicles.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-08-2018 at 09:21 PM. |
05-09-2018, 01:50 PM | #3 | |
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
05-09-2018, 04:28 PM | #4 |
Volcanos?
05-09-2018, 11:43 PM | #5 |
Moderator
Adding Pulse (delay or intermittent) wipers is easy to do... Install the pulse equipped switch and the delay module instead of the more expensive switch without the pulse control resistors. Why is the base model switch more expensive? prolly volume... You may not be able to find the AC Delco non-pulse switch at all.
I'd steer clear of the aftermarket turn and column mount wiper switches. These two switches are such a pain in the caboose to change it's not worth installing the super cheap parts and finding out they only last a few weeks or fail instantly. Even the normally top-shelf Standard Ignition brand switches seem to have a lot less than stellar reviews. Wiper switches 1984-1987 AC Delco D6283D W/O TILT (N33), W PULSE (CD4) 1984-1987 AC Delco D6354A W TILT (N33), W PULSE (CD4) Turnsignal switch 1984-1987 AC Delco D6262D Stalk 1984-1987 AC Delco 22510144 W Pulse (CD4), W/O Cruise (K34) 1984-1987 AC Delco 19244690 W Pulse (CD4), W Cruise (K34) Pulse (delay) module 1984-1987 AC Delco 15598496 Pulse Wiper Module (CD4) Dorman makes a replacement wiper arm for around $20 that will replace the stripped unit. The base of the original GM wiper arm is made of cheap Zinc alloy. My guess is it was already stripped and re-installed with bubble-gum and sitcky-tape to sell the truck.
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-09-2018 at 11:50 PM. |
05-10-2018, 12:42 AM | #6 | |
05-10-2018, 12:45 AM | #7 |
Do I need to replace the turn signal switch or did you throw that in for good measure?
05-10-2018, 09:00 AM | #8 |
Moderator
I threw it in JIC you needed it.
You have to pull the upper housing to change the turnsignal switch because the harmonica connector will not pull through with the upper housing installed... The harmonica connector hangs up on the plastic guide in the lower column that's held in place by the upper housing. You could extract the Pak Con terminals from the harmonica plug and re-insert them once the wires are down the column but that's a pain in the caboose.
And please let us know if and how your repairs were successful. |
05-10-2018, 02:46 PM | #9 | |
