Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-19-2018, 01:00 PM   #1
1966 K10
1966 K10's Avatar
New replacement 2 barrel carb feedback
This came through my Amazon feed and wondered if anyone has any feedback on quality/function.
It says 70-79 5.7, is there any difference in bolt pattern that would keep it from working on an earlier manifold? Im assuming its due to the electric choke that it shows the later applications.
Thanks for any info.
https://www.amazon.com/Carburetor-Ro...ype=automotive
1966 K10 is offline   Reply With Quote
Old 05-19-2018, 01:54 PM   #2
geezer#99
geezer#99's Avatar
Re: New replacement 2 barrel carb feedback
Depends how early.
There was a small base and a large base carb.
Small base was 3 1/4 inches from bolt hole to bolt hole.
Large base was 3 11/16.
That carb is likely a large base.
Old 05-19-2018, 02:48 PM   #3
1966 K10
1966 K10's Avatar
Trying to make a 350 look like a stock 283 for my 66. Would the stock 66 manifold be early or late?
Old 05-19-2018, 03:50 PM   #4
geezer#99
geezer#99's Avatar
You’d need to measure it.
How do you plan to use a pcv on your fake 283.
Old 03-08-2019, 10:10 PM   #5
1966 K10
1966 K10's Avatar
Well, finally was able to get to the truck and pull the carb and you were right its the early 3 1/4 small bore manifold/carb.
As far as the PCV, its a factory closed system so will be leaving it intact.
