05-22-2018, 08:32 AM | #1 |
Yet Another Power Door Lock Question
Door switch on my '88 K5 operates the RH side just fine but not the LH side. RH switch does the same thing.
I've checked the switch, the actuator solenoid, there is power to the switch. Any ideas as to what I can check next? I'm assuming since there is power to the switch the relay should be okay. Am I off on this assumption? (And if so, can the relays still be found?) Thanks for your help. trukman1
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
05-22-2018, 10:11 AM | #2 |
Re: Yet Another Power Door Lock Question
You say you have power to the switch in question. Does it have power out when switched?
05-22-2018, 02:28 PM | #3 |
Might be a bad connection at the actuator. Had a devil of a time with my install. Must have removed the wires, cleaned and bent contacts two or three times. Would work for a while then quit.
Finally got a good, clean connection and made sure the plug had a good amount of di-electric grease to prevent corrosion. Been working for over a month now. Also, the actuator needs a good ground to the door shell.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
05-23-2018, 09:56 AM | #4 | |
05-23-2018, 09:51 AM | #5 | |
I have power to the switch but not to the solenoid. Tested solenoid on battery and it seems to work fine. Thanks, trukman1
