06-11-2018, 06:42 PM | #1 |
Egg off throttle body
What's the best and permanent way to plug this?
For some people driving is one long series of corrections... |
06-11-2018, 06:51 PM | #2 |
Re: Egg off throttle body
Not egg. I meant egr. Auto correct on my phone gets me in trouble sometimes.
06-12-2018, 12:01 AM | #3 |
BMW & ASE Master Certified
Rubber caps from auto parts store will dry rot in a few years, simple and cheap. Not sure of any permanent solutions..
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-12-2018, 10:06 AM | #4 |
Re: Egr off throttle body
That's what I've got on there now. I don't think it will last long.
06-12-2018, 11:55 AM | #5 |
you can tap it for NPT and screw in a small brass plug
it's the EVAP port by the way, pulls fuel vapor from tank.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
06-16-2018, 11:07 AM | #6 |
It shouldn't actually be plugged, should it? If so the engine won't be able to pull fresh air through the crankcase via the PCV system.
I -thought- it was a metered orifice that flowed at a known rate and as long as you provided it with a supply of fresh filtered air, the ECM took account for it in the tune. No?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-16-2018, 11:00 PM | #7 | |
06-18-2018, 04:06 PM | #8 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-19-2018, 10:15 AM | #9 |
Thanks for the replies on the EVAP. I ended up using a small piece of hydraulic line with a fitting pressed on it and a threaded cap. I think it will last.
